belkin router help:)
Old Jan 9, 2007 | 07:18 PM
Chris Honeywell's Avatar
Chris Honeywell
Default belkin router help:)
Hey hope you can all help me again
basically got a new laptop and its wireless enabled.
originally set up my router with an older laptop and i acessed the router via a utility program.
Now that laptop is gone .. and the new one dos not have this utility.i did have my security wep number written down on a bit of paper as i used it to set up this laptop
I've lost it and i need the code for another laptop and i have no idea how to access the router now to get the code.
I know last time i acessed the router via the net using an ip number?? to acess the router directly..
anyone help??
Old Jan 10, 2007 | 11:19 AM
DanRSturbo's Avatar
DanRSturbo
Open internet explorer and go to http://192.168.1.1 and it should open the router, chances are the username is admin, and the password will either be password or admin.
There you can go to the wireless section, and find your wep encryption key
Old Jan 10, 2007 | 02:45 PM
Frogford's Avatar
Frogford
but yo may wel have to plug your laptop in with a network lead if you have no WEP key ! Once you have the key and sorted the lappy then you wont need the cable anymore !
Old Jan 10, 2007 | 11:49 PM
DanRSturbo's Avatar
DanRSturbo
How did you get on Chris ??
On a side note Andy, nice choice of team m8
Old Jan 11, 2007 | 05:16 AM
Frogford's Avatar
Frogford
After the football topic in General Discussion I thought I would show some team colours !
Old Jan 16, 2007 | 08:44 PM
Chris Honeywell
Still can't acess it m8
tried all sorts of searches on the net but can't find any address that works
Old Jan 16, 2007 | 09:36 PM
Frogford's Avatar
Frogford
plug a computer into the router and type 192.168.2.1 into explorer (you cannot do this wirelessly as you cannot access the router because of the wep security that you have no key for !)
. You will then be prompted for a username and password, they are usually admin and admin or admin and password. unless you changed these when you originally setup your router ! then your on your own here as I wouldnt have a clue what you named them !
you should now be in the admin settings of your router. no goto the wireless ecurity settings and you see your wep key and which key it is (Im sure you get a choice of 4, one of these will be selected as your wepkey).
Once you have the key then enter it into the wep key field in the wireless section under the control panel !
fingers crossed job done !
Old Jan 16, 2007 | 09:55 PM
DanRSturbo's Avatar
DanRSturbo
If that doesn't work, there may be a way of setting the router back to all factory defaults ?
Old Jan 16, 2007 | 10:01 PM
Frogford's Avatar
Frogford
a quick google search found this :
Turn your router upside down or look on the rear for a small pinhole. It should be labeled "RESET." With the router turned on, unbend a paperclip and insert it into the hole. You will feel a small button inside, which you'll want to press with the tip of the clip. Hold the button down for 10 seconds, or until the lights on the front of the router stop blinking. The router will reboot within about a minute and be ready for configuring from its virgin state.
let us know how you get on
Old Jan 18, 2007 | 06:52 AM
Chris Honeywell
OK i got it sorted so lots of thanks guys
put in the ip with the router connected to the computer and i was straight in!!!!..
Really appreciate the help thx
Old Jan 18, 2007 | 09:52 AM
Frogford's Avatar
Frogford
well done matey !
JonnyBravo
18
Feb 13, 2006 10:00 PM
croakey
Jan 16, 2006 02:42 PM
Benni
Computers, Consoles and I.T.
Dec 3, 2005 09:48 PM
POPEYE
21
Sep 8, 2005 08:21 PM
Frogford
Jul 24, 2005 06:40 PM
