anyone use Belkin routers ?
I have been trying to setup my belkin router corectly so I can download torrents, I need to setup a port for the data to transfer through.
If I go to Application gateway on my router settings I get 2 fields to fill in
trigger port and public port.
When I setup my Downloader (azureus) for which port it should see and I enter the number , for example 13000 and then test it I get a failed message.
How exactly do I fill in the 2 fields in my application settings ?
Hopefully someone knows exactly what i mean as I'm clueless with this and its doing my head right in lol
Cant you just enable upnp? If its a new router it should support it. Port forwarding can be a pain in the bottom. Speak to belkin tech on monday.
Just to cheer you up, belkin is the worse gear I have ever configured. Buy something better if you really struggle.
Good luck.
Good luck.
lol great advice there mate
No flocking way I'm changing the router, I just brought 2 new monitors and a new pc
I'll ring the tech helpline
cheers anyway
cheers anyway
I had a Google around and came up with this Jonny...
http://www.portforward.com/english/r...outerindex.htm
They list quite a few Belkin routers there, I'm sure yours will be in that list somewhere.
Cheers,
Andy
Cheers,
Andy
Cheers Andy
Still have no clue whatsoever how to sort this
That site doesn't list the exact router I have but its close
mine is F5D7632uk4
Anyone else have an idea what the hell I need to do to make this work
mine is F5D7632uk4
I'm pretty sure this is close enough?
Sounds like the model number of your router is just denoting that it's the UK version?
http://www.portforward.com/english/r...-4/Azureus.htm
Looks like it's the right one!
Cheers,
Andy
Cheers,
Andy
ok thats quite good,
atleast I could get my head round all that but on Azureus I'm still finding that in the que position it says last ?
That doesn't seem right ?
Should I reboot maybe ?
Queue position? Try right clicking and the torrent and selecting 'Force start'
It'll probably come up with the status as a yellow face until you set your MAC settings, but I haven't bothered and get very good speeds with it on the little yellow man
Could you Alt + Print Screen us a screengrab of the error message you're getting?
Cheers,
Andy
Cheers,
Andy
The alt and print screen thing isn't working
something must now be working as Nortons just blocked a supposed intrusion attempt ?
it gives me the source Ip address and destination ip address
does norton need switching off or has someone now got access to my pc ?
Ahh, you'll have to add the 'port' you've opened up as a friendly port or whatever Norton calls it. Its not being attacked, just your Azureus software is now trying to access it and Norton is saying 'nah, sorry pal'
Cheers,
Andy
Cheers,
Andy
ok i clicked on allow this on norton
If I run a NAT/ Firewall test on Azureus then it fails just says NAT error ?
so something still isn't working right grrrr
Mine comes up with this error as well - it's to do with setting up MAC addresses, it still works as it should when downloading torrents.
Time to try it out on those links I sent you I think!
Cheers,
Andy
Cheers,
Andy
I had the same model as your one
F5D7632uk4, never had no problem setting it up and my Azerues worked great. Didn't need to put anything in the fields either.
