wireless help
Old Jun 3, 2006 | 11:40 AM
swerv's Avatar
swerv
Default wireless help
right need some help with setting up a wireless system in my parents house.
the scene:
1 desktop pc with pipex 2mb adsl, this is running on a wired modem atm.
1 laptop with wireless built in
i need to run the desktop on wires still to keep the speed up, ethernet?
i need to run the laptop wireless.
i need to know what equipment to buy to do both these jobs in one and most of the routers ive seen are only wireless and have no connection for wires!!
am i right in thinking i need a modem router?
also is their a speed difference between routers? whats the fastest, obviously cost effective.
any help appreciated
Old Jun 3, 2006 | 04:21 PM
Thrush's Avatar
Thrush
Irritating c........
As far as I know, and have only briefly looked into wireless ADSL (mine is all wired) you would be able to do what you want with an ADSL Modem Router.
Something like the NETGEAR DG834G would be perfect for you. It's a typical 4 port modem router (ie, plug the phone line directly into it and it has 4 wired ports (ethernet RJ45 cat5 cable) to connect to PC's to provide broadband internet to). It also has a WAP (Wireless Acces Point) built in to allow you connect to the modem via wireless connection.
Old Jun 3, 2006 | 10:20 PM
Dan B's Avatar
Dan B
I'm using the Netgear DG834G v2 here, and it's a nice piece of kit......wireless works anywhere in the house, on my laptop, nice and quick; speeds by wire are decent, and it's easy enough to configure.
Netgear aren't brilliant with firmware, but I guess you can't have everything......mine's still running on a relatively old firmware, because I know everything works with this version, whereas it doesn't with the newer versions I tried.
To answer a few of the original questions, there won't really be a speed-difference between routers and, if there is, you won't notice it; and yes, you need a wireless modem-router. And then, when it's all set up, you can keep the current wired-modem as a spare, since the wireless modem-router will do the job of that aswell...
Old Jun 8, 2006 | 07:23 PM
swerv's Avatar
swerv
cool ,thanks for that guys .
i have recently set the System up with Some Success as its my first go ,i need Some help configuring the ethernet port to accept File Sharing as there is Something -Stoping this ?
thanks again
Old Jun 11, 2006 | 10:08 AM
DanRSturbo's Avatar
DanRSturbo
It could be the firewall that's stopping it ??
Thrush
Computers, Consoles and I.T.
Oct 19, 2005 03:24 PM
Snowy_Astra
Sep 29, 2005 04:03 PM
Gra
11
Aug 13, 2005 01:45 PM
BigNige
Nov 20, 2004 12:02 AM
Turbo lag
Sep 6, 2004 06:57 PM
