Another wireless network question
Old Mar 20, 2006 | 01:36 PM
Olliexr4x4's Avatar
Olliexr4x4
Default Another wireless network question
I have finally got myself a laptop
Both my PC and my laptop are connected wireless to my router, how can I network the 2 together so I can share files. Do I need 2 wireless network connections in each?
Old Mar 20, 2006 | 01:40 PM
EssexBoyRacer's Avatar
EssexBoyRacer
does your router act as a hub too? (generally they do)
you should already be able to share files. You will need to share out a folder on one machine and ensure any permissions / firewalls are configured to allow connections. - it can be a bit of a headache - sometimes best to disable any personal firewalls, get the share working. Then reenable the firewall and configure.
Old Mar 20, 2006 | 06:44 PM
Olliexr4x4's Avatar
Olliexr4x4
It works I have set up the partition of my PC as shared and mapped it as a drive on the laptop, just what I was wanting
I am a little concerned over security though. I have WEP security enabled on my router connection and as the two PC's are networked through the router des this mean they are secure. I just want to be sure that nobody can access my shared partition other than me
Old Mar 20, 2006 | 08:10 PM
DanRSturbo's Avatar
DanRSturbo
Yeah, basically they are secure. Although,I would just unshare the partition when not in use
Old Mar 21, 2006 | 08:29 AM
EssexBoyRacer
if your concious of security turn broadcasting off on your router. this means the wireless network is there but you caan only see it if your connected. also make your share hidden by adding a $ to the end of the share name. again you will only be able to connect to it if you know the name of the share.
Old Mar 21, 2006 | 05:42 PM
Olliexr4x4's Avatar
Olliexr4x4
I tried turning off Wireless SSID Broadcast, and I lost my connection and had to plug into the router to change the setting back
I must be doing something wrong
Old Mar 21, 2006 | 06:14 PM
EssexBoyRacer
make sure your not turning the wireless off completely.
you only want to turn off broadcasting.
it may take a minute for your machine to reconnect once you turn off broadcasting - especially if the router has to restart.
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
