Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
escort van engine??
Old Oct 5, 2008 | 09:39 PM
alexno1dj's Avatar
alexno1dj
Default escort van engine??
Hi folks,
Does anyone know anywhere in the Midlands where would fit and source a endura td lump in my n/a endura de van?
any help would be great!!
Old Oct 6, 2008 | 01:56 AM
bluescortcossie's Avatar
bluescortcossie
as you are in derby , Loom's scrap yard in spondon will get one out for about £100
what mark van have you got ? , if its a mk5 (91) on its a straight swap although the fuel pumps are coded to the key so you will need the original key or bypass the PATS which means taking the pump off
as for fitting , most garages will fit it but they wont be cheap , if i wasnt so busy i could have fitted it for you !
Old Oct 7, 2008 | 12:34 AM
alexno1dj's Avatar
alexno1dj
Ah thanks. i know what you mean about being busy tho.
Nice to see your from derby, i live in Oakwood so looms would be handy. So would i just ring them up and get them to find me one? How will i know if its any good tho?
Its a Mk6 van and i would be happiest with the easiest swap poss, maybe a Td although id rather get a Tdi.
Old Oct 7, 2008 | 01:07 AM
bluescortcossie
yeah just give them a ring and they will take about a week to get it out , they dont keep parts on the shelf anymore , it will come with a warranty for about a month i think
they crop up on ebay quite often and dont fetch much
the TDI is just as easy to fit as the TD , the only difference in engines is the turbo , fuel pump and intercooler
Old Oct 8, 2008 | 06:54 PM
alexno1dj's Avatar
alexno1dj
So going on the basis im fairly confident doing most work on my cars etc you think its something thats fairly easy to do??
How long do you think it would take?
Old Oct 8, 2008 | 06:55 PM
alexno1dj's Avatar
alexno1dj
Oh and with it being a mk6 will i have any proms with the PATS system etc
Old Oct 8, 2008 | 08:43 PM
bluescortcossie
if you have access to an engine crane you should be able to do it within a day
it took me 2 days to fit a TDI into my mk4 but loads of things had to be fabricated and i wasnt really rushing with it
if you can get hold of an early engine it wont have a PATS coded pump and all you will have to do it get a ignition live to the fuel shut off solinoid
if you get a later engine you have 2 options,
1. make sure you get the key , PATS unit and any relevant loom from the doner car and fit into yours , or
2. take off the fuel pump and cut away the shroud at the back that covers the fuel valve then snip the wires and re-wire onto a ignition live
i chose the latter with mine as the belts were being replaced anyway so its not much more of a job to take the pump off
Old Oct 8, 2008 | 08:49 PM
alexno1dj's Avatar
alexno1dj
Ok thats a great help, thankyou.
So what age of engines are the early engines?? This will prob be the easiest option.
Old Oct 8, 2008 | 09:13 PM
bluescortcossie
you want an early as possile escort engine (91-)
the mondeo engine is the same but you would have to sway around a few things on it , escort just makes life easier
the problem is finding a low milage 91 escort engine is going to be difficult , i was you i would look for a low milage later engine and while the engine is out replace the belt and re-wire the fuel shut off
Old Oct 8, 2008 | 09:57 PM
alexno1dj's Avatar
alexno1dj
Ahhh rite i see,
Good advice and thankyou. I shall start searching for a decent newer engine then.
As you say, a decent 91 engine is going to be very difficult to find.
So just to clarify,im looking for a 1.8 endura Tdi engine out of an escort, so roughly about an R reg ?
Old Oct 8, 2008 | 10:21 PM
bluescortcossie
that's going to be the easiest
you will find there is a lot in the scrappys with snapped cambelts as people dont think they need to do them so for the sake of £60 replace the belts and tensioners as its very easy while the engine is out
Old Oct 8, 2008 | 11:11 PM
alexno1dj's Avatar
alexno1dj
yeah thats a good point, dead simple when engine is out of bay
Old Mar 2, 2009 | 07:41 PM
Escow-Van's Avatar
Escow-Van
Sorry to dig out an old thread, but this may be the saviour of my van
Did you manage to find an engine? How'd the swap go?
Cheers -
Old Mar 3, 2009 | 08:06 AM
cossiecrew's Avatar
cossiecrew
just go and but a rotten td escort for a few hundred quid and strip it yourself thats what id do
Old Mar 5, 2009 | 06:15 PM
Kenty91's Avatar
Kenty91
ive heard that looms in spondon have just got quite a few escort vans in mk5/6 so im goin in on saturday to have a mess about with them all
Old Mar 6, 2009 | 12:13 AM
cossiecrew's Avatar
cossiecrew
was there today was about 8 i raped bits off nearly all of them
Old Mar 6, 2009 | 12:27 AM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
i have a complete van going cheap see cars forsale thread
would have everything you need plus spares
Old Mar 6, 2009 | 06:38 PM
Kenty91's Avatar
Kenty91
what did u take, u best not of took what i need haha
Old Mar 21, 2009 | 07:55 PM
didskid's Avatar
didskid
hi this has been a handy thread to me as i am thinking of doing the same thing , my van is a 99 t plate non turbo endura ,some people say its a mark five and some say its a mark six , how can i tell ,
cheers , also how much better is a tdi in comparison to a td endura engine , does it make a lot of diff ??
Old Mar 22, 2009 | 02:18 PM
Escow-Van's Avatar
Escow-Van
I believe it's a mark 6 on a T plate, if the indicators on the front are clear (not orange) then its a mark 6. The standard TD that was put in vans makes 75bhp and the TDI from other cars made 90bhp. With the non turbo making 60 it doesn't seem worth the trouble of swapping it for the TD, only a 15bhp gain.
The TDI is much more tunable too as it has a bigger turbo and fuel pump, people do get 170bhp out of them!! although 150 isn't too hard to achieve if you use a FMIC. Having the intercooler above the exhaust and turbo isn't very clever
Old Mar 22, 2009 | 02:19 PM
Escow-Van's Avatar
Escow-Van
This is a pretty good page, its for a fiesta but still useful.
http://www.mwstewart.co.uk/cars/enduratdi/
Old Mar 24, 2009 | 09:43 PM
didskid's Avatar
didskid
Default blue !!!
what do you have to mess about with if you use a mondeo tdi engine
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
vdubo7
Aug 2, 2015 08:17 PM
Old ford
Jul 31, 2015 06:50 AM
