zetec s silver top knocking top end?
help i brought a zetec s and on the way home i heard a knocking noise from the top end i think any one got any ideas common faults on these models any help plz
is what you say fixable what parts would i need
cheers tom
As said likely the tappets, could always try some Wynns valve lifter lube first, as often works, within minutes if going to, but if not will need new tappets, might as well do set while there.
thanks
JoeyBoyden
04-01-2024 02:36 PM
