Peugeot 205 with 4wd cosworth engine and running gear.
Old 22-01-2017, 08:04 PM
  #1281
Caddyshack
Caddyshack's Avatar
I think Jay at export can get me some figures
Old 22-01-2017, 08:15 PM
  #1282
jonfoc
jonfoc's Avatar
Good stuff. Get spring length and id too.
Old 23-01-2017, 06:57 PM
  #1283
Caddyshack
Caddyshack's Avatar
Thanks Jon, will do.
I think the rack may have a little play at straight ahead although this could still be geo set up but I have ordered a new rack from Burtons as a precaution and then will rebuild my current one or have it done as spare.
Old 25-01-2017, 02:22 PM
  #1284
Caddyshack
Caddyshack's Avatar
I have ordered a new center bearing for the rear prop as I think there is a bit of play in my current one.
I took the car to Basingstoke today so about 25 miles each way and it performed really well, it was very wet so I only used low boost setting. I am having a slight modification done to the exhaust now that it doesn't need to pass between the box and the anti roll bar.
Old 27-01-2017, 05:15 PM
  #1285
COLEYST200
COLEYST200's Avatar
Sounding good mate . Any news on your rear beam ??
Old 27-01-2017, 05:37 PM
  #1286
Caddyshack
Caddyshack's Avatar
Newly sorted zorst is spooling up the turbo 250 rpm sooner so happy days. The bend and pinch where the anti roll bar was had created a restriction.
Mark has promised delivery by next weekend so shipped at end of month, he is very aware that we fall out then.
Old 28-01-2017, 10:17 AM
  #1287
Caddyshack
Caddyshack's Avatar
When I put in the prop shafts I used a second hand rubber donut which I didn't like the look of, I went to change the centre bearing today and i think I had about 10 miles left in the donut. Now, where do I find another and aren't there 2 types?
Old 28-01-2017, 12:31 PM
  #1288
Caddyshack
Caddyshack's Avatar
Old 28-01-2017, 04:59 PM
  #1289
Caddyshack
Caddyshack's Avatar
In anticipation of the rear beam arriving I have stripped out the rear beam and diff today.
I found 2 of the star drive, drive shaft bolts loose and the drivers side engine mount had 1 loose bolt and one missing which lead to bending of the upper 2 and the engine had moved....so, just goes to show that a regular spanner check is wise.
I will order some new bolts from margnor.
Old 28-01-2017, 05:28 PM
  #1290
Caddyshack
Caddyshack's Avatar
Managed to buy a new donut on eBay...doh I gave away the last one.
I wonder if it is worth making a 1mm thick steel ring for each side with a little play in the holes to tighten the donut up and stop it coming apart? Or maybe lock wire to limit movement?
I have worked out that the play in the centre bearing may have caused this and am fitting a new one plus making a better mount for it as I think mine was 2mm too high and putting the donut under pressure / vibration.
Old 28-01-2017, 05:33 PM
  #1291
McCloud 85
McCloud 85's Avatar
That doughnut did the same in mine. Couldn't find a readily available replacement so had to move onto the later type. This for me meant sourcing a new output shaft for my box to replace the existing one as someone had cut the spigot off required to fit the new type doughnut to fit the old.
Then a later spec front section of the rear 4x4 prop sourced and fitted and it now means I have the newer doughnut type which is readily available. I think I put some photos up of the two types and changes I made on my thread if that's any help to you.
If your box doesn't have the right output shaft, instead of changing the output shaft (which was nearly impossible to source) or getting a new box I believe GEARS (I think) have made a handy adaptor where all you do is swap the drive flange but for their type which has a spigot machined onto the new nut. I would have done this if I had known before I got the output shaft replaced.
Worth a little research as it's a very simple fix for the box!
Hope that helps
Old 28-01-2017, 05:34 PM
  #1292
McCloud 85
McCloud 85's Avatar
Ha and there's me saying it was difficult to source!!
Old 28-01-2017, 05:35 PM
  #1293
Caddyshack
Caddyshack's Avatar
Thanks mate, I think it is only time before they run out and maybe they have all perished by now?
Old 28-01-2017, 08:34 PM
  #1294
McCloud 85
McCloud 85's Avatar
Mine wasn't quite as bad as yours but the rubber had split away from the aluminium in 3 places. Even old stock must be coming close to 20 years old now so not surprised they're not lasting, especially with the higher power we are all pushing.
Old 29-01-2017, 07:58 AM
  #1295
Caddyshack
Caddyshack's Avatar
The good news is that if they all fail then someone will remake them. I was reading old threads on here and it seems a BMW one might fit, assuming they are still made. I bet somewhere in this country or USA could or does make them....might have to look in to a batch and then sell them on eBay?
Old 29-01-2017, 08:05 AM
  #1296
Caddyshack
Caddyshack's Avatar
I wonder if this might work?
http://www.burtonpower.com/propshaft...2-proprj1.html
Just worked out that it is the later type, might get one in case I need to swap to later output shaft if the second hand one is no good.
Old 29-01-2017, 08:14 AM
  #1297
Caddyshack
Caddyshack's Avatar
I found this pic, would the cable ties really help? If so I could use the metal straps that you use around a cv joint?
Old 29-01-2017, 08:17 AM
  #1298
Caddyshack
Caddyshack's Avatar
I have just read that Wenny converted to a uj and did away with the doughnut. I will get Propshaft services to do that if this doesn't work.
Old 29-01-2017, 11:07 AM
  #1299
Caddyshack
Caddyshack's Avatar
BEAM UPDATE: Mark has been in touch and has suggested that he will drive the beam down to me to avoid the powder coat being damaged in transit and has agreed to come next weekend. I have previously said that he can have my old beam so he can take that away with him. Will post pics of it when it arrives.
Old 29-01-2017, 02:08 PM
  #1300
jonfoc
jonfoc's Avatar
Patience is a virtue Toby,it'll be worth it in the end. I'm hoping to hear of some progress with regards to my orders soon.
Caddyshack (29-01-2017)
Old 29-01-2017, 04:27 PM
  #1301
Caddyshack
Caddyshack's Avatar
Today I made much better mounts for the centre bearing, I have left the last bit unfinished so I can adjust the bearing so I can be sure to be bang in line with the prop once the new doughnut arrives.
I have made the mount so that it also ties in to the old harness mount holes as well as the normal ones to stop it moving.
Tomorrow I will pop out at lunchtime and get the new bolts for the engine mount.
Old 29-01-2017, 04:31 PM
  #1302
Mark V8
Mark V8's Avatar
It will be worth the wait
Caddyshack (30-01-2017)
Old 31-01-2017, 07:56 PM
  #1303
Caddyshack
Caddyshack's Avatar
I got the pics through today of my beam, it does look the nuts, really looking forward to getting this bolted in.
Old 01-02-2017, 06:13 PM
  #1304
Mark V8
Mark V8's Avatar
Depending on how much of a hurry you are in and how much of a bufty you are, it might be worth getting the tube nuts used for adjusting the rod ends Zinc plated.
Mine were bare steel and would soon rust under a car, so I had them done.
Haven't found a source for plated 7/8 unf rod ends though as they are bare steel also.
They would be difficult to plate conventionally, this kind of thing might do them - just don't want to spend Ł70 to find out
http://www.frost.co.uk/brush-on-zinc-plating-kit.html
Old 01-02-2017, 08:37 PM
  #1305
Caddyshack
Caddyshack's Avatar
Thanks, I am amazed by how the compression struts have tarnished, I am going to powder coat them.....I don't want to hide it away, if it snows I still take it out so the salt has an impact.
Old 04-02-2017, 12:53 PM
  #1306
Caddyshack
Caddyshack's Avatar
My new doughnut arrived today, I added some adjustment to the gearbox support so now I am certain that it is 100% straight.
A lot of people told me to do away with the donut and solid mount it, whilst looking at the old, broken donut I realised that with a little bit of work I could just line up the 3 prongs on the output flange, straight through the same line as the prop, I had to remove a bit of metal and all of the rubber but now it bolts straight through and on to the prop. I have t lost any strength from original and the centre bearing is still in place.
Now I can sell the mint replacement doughnut that I bought (once this has been properly tested)
Old 04-02-2017, 05:05 PM
  #1307
Marc sierra
Marc sierra's Avatar
With a solid mount, won't it put a lot of strain on the output bearing of the gearbox if the prop isn't 100% perfect aligned?
Old 04-02-2017, 07:00 PM
  #1308
Caddyshack
Caddyshack's Avatar
Yes. I think it would so will check everything. I actually think that the centre bearing rubber on the prop would move about first.
Old 04-02-2017, 07:04 PM
  #1309
Caddyshack
Caddyshack's Avatar
Old 04-02-2017, 07:11 PM
  #1310
Caddyshack
Caddyshack's Avatar
Monster Dave is making me some new side badges, they will be black with red inserts
whizzisat114 (05-02-2017)
Old 04-02-2017, 07:32 PM
  #1311
smiley
smiley's Avatar
Very nice mate
Old 04-02-2017, 08:20 PM
  #1312
jonfoc
jonfoc's Avatar
Nice finishing touch there mate. Dave did my vin tags, he has got talents.
Old 04-02-2017, 09:34 PM
  #1313
Mark V8
Mark V8's Avatar
Very smart
Caddyshack (04-02-2017)
Old 04-02-2017, 09:39 PM
  #1314
800bhp
**RS COSWORTH**
800bhp's Avatar
Badges look good what about having them with clear coat.
Beam looks good not sure about the colour thoe must be a smurf thing
Old 04-02-2017, 09:44 PM
  #1315
Caddyshack
Caddyshack's Avatar
I did think about clear coat but car is very much black and red, smurf colour has actually now gone, pics to follow, all black now,
The parts underside are now either black or red and seeing that the stone chip is all black I thought red might contrast well....I know what you mean though....will just have to see how it looks, if it looks crap I will go black colour next time around.
800bhp (04-02-2017)
Old 04-02-2017, 09:49 PM
  #1316
Adam-M
Adam-M's Avatar
Beam looks good looking forward to hearing your reviews on it
Caddyshack (05-02-2017)
Old 05-02-2017, 09:43 AM
  #1317
Marc sierra
The beam looks good apart from the colour lol.
I'm curious to hear how you like the handling with the new beam.
Old 05-02-2017, 10:08 AM
  #1318
smiley
smiley's Avatar
When are you fitting it toby?
Old 05-02-2017, 01:12 PM
  #1319
Caddyshack
Caddyshack's Avatar
I will probably get it in this coming week and a little of next weekend.
Old 05-02-2017, 01:39 PM
  #1320
smiley
smiley's Avatar
Nearlly finished
Quick Reply: Peugeot 205 with 4wd cosworth engine and running gear.
