Capri 2.8 project - yes or no??
Old 08-01-2017, 06:11 PM
TomPengelly
Kapow!!
TomPengelly's Avatar
Default Capri 2.8 project - yes or no??
I've been offered a 2.8 Capri. It runs but not very well. moT only ran out in March 2016.
has crusty wings, front panel, inner wings ect, a fibreglass Bonnet with aweful looking Bonnet pins that would obviously need to be replaced if I was going to do it properly.
also has had a rubbish shocker turret repair- see photo! Is this all easily sort-able!?
looks all original inside and in not bad condition.
Whats a good price?
And are they easy easy to work on- i.e. Taking engine out, re-building ect?
thanks in advance 👍
Old 08-01-2017, 06:28 PM
cossynut2
cossynut2's Avatar
Depends on how bad the rust is IMO. I would be concerned if that much rust is visible how bad is it the further you dig. To get it back to A1 condition would be a lot of hard work. Can you pick it up for a cheap price? Have you got a decent sized garage to work on it?
They are fetching good money now but of course in top condition.
Your call but think carefully before you take the plunge.
Old 08-01-2017, 06:29 PM
Caddyshack
Caddyshack's Avatar
Buy yourself a mig welder and get stuck in but be prepared for a project
Old 08-01-2017, 06:35 PM
3i Jim
3i Jim's Avatar
As said. Get a welder and get stuck in! Capris will alway be cool ��
Old 08-01-2017, 06:43 PM
gcfcos
gcfcos's Avatar
If it was cheap enough I'd buy it and slap an mot on it, use it for a year for a bit of fun and then strip it and restore it. I'd only personally get involved if I had a decent sized garage/workshop to do it in
Old 08-01-2017, 06:50 PM
TomPengelly
Kapow!!
I need to make an offer. How much is too much?
Old 08-01-2017, 06:56 PM
Caddyshack
Caddyshack's Avatar
Don't bid much, it is not far from scrap. I paid £1200 for a 205 gti that was much better than this. I would be more of a mind that "I will save it"
Old 08-01-2017, 06:57 PM
3i Jim
3i Jim's Avatar
Start at low at £500 and go from there, personally wouldn't pay any more than 2k.
Old 08-01-2017, 07:01 PM
Adam-M
Adam-M's Avatar
Probably need a restoration to pass an MOT, well a legit one anyway
Old 08-01-2017, 07:39 PM
gcfcos
gcfcos's Avatar
Ah I should have said I would mot it myself lol
Old 08-01-2017, 08:04 PM
costina
Live long and prosper!!
costina's Avatar
I would like that but be carefull it looks like a lot of work.
Old 08-01-2017, 09:09 PM
ray barker
ray barker's Avatar
chap i work with just done a mk1 capri v6 said the engine was a dear old game to rebuild couple of grand sumut about the cams were not easy to get his wasnt an essex i dont thinks dont see many manual ones just check things like a pillars were the door hinges go are half decent floor pans wings f pannal d skins are easy enough make sure its not gone bad were it would be really tricky to get wright
Old 09-01-2017, 09:03 AM
Cos500
Cos500's Avatar
Get it bought and give it a go rust doesn't look that bad for a Capri get the welder out and get stuck in, if it doesn't work out break it, don't see enough capris on the road.
Tried to buy a brooklands local to me, been sat on a drive since I was a kid under a tarp, knocked on the door 20 years later and I'd missed it by two weeks, sold it, bugger
Old 09-01-2017, 11:50 AM
Get it saved.
Old 09-01-2017, 07:09 PM
Adder
Adder's Avatar
That's a basket case fella. A couple of things you should consider is the parts like many older Fords these days are getting hard to find. You've mentioned a dogey front panel which are going for around the £600 mark not to mention front wings ! Fuel tanks are like rocking horse poo. On the plus side it looks like an early 4 speed which folks like but unless the car has some sort of sentimental value it's just a breaker.
Hope this helps
Adder
Old 09-01-2017, 07:25 PM
costina
costina's Avatar
Did you make an offer ?
Old 09-01-2017, 07:53 PM
rallycross
rallycross's Avatar
That does not look too bad and it's a long way from being a basket case more like an easy project if it's not too rotten underneath
Old 09-01-2017, 07:58 PM
lee2cossies
lee2cossies's Avatar
Hope this helps
Adder
Its an early 5 speed with shark grey interior, you can get tanks made in alloy now for £400, id say looking at it, it isn't too bad and definitely worth saving too good too break, unless its rotten underneath. Much worst 2.8's than that are fetching £2k now so this could be a good buy if the price is right.
Old 09-01-2017, 09:25 PM
cossynut2
cossynut2's Avatar
The op needs to get it up on a ramp to have a good look at how bad the rust is. As we all know when Ford built these back in the day rust proofing was virtually unheard of.
I would want to be certain it can be saved before I would buy it.
Old 09-01-2017, 09:31 PM
TomPengelly
Kapow!!
Thanks for all the replies
im taking it to work before the end of the week and il have a proper look at how bad it is on a ramp.
The owner has been keeping an eye on eBay, I think he knows it would make around £3k. Not sure I would want to give that much for it- but the restored ones fetch 10k plus so I'm not sure if it's too dear or not...
Old 10-01-2017, 08:14 AM
Cos500
Cos500's Avatar
Like you've said get it on the ramp and have a good look, I'm sure if it has negative points underneath you'll get a better price so long as it's not completely rotten, I'd be wanting it less than 3k looking at it without getting underneath but for a Capri it looks pretty good to be honest and a good interior.
Old 10-01-2017, 11:17 AM
cossynut2
cossynut2's Avatar
You could end up spending close to the £10k if it is really bad. I think £3k is to much for it. You could save money if you can do all the welding, paintwork and engine rebuild your self but if you have to get it done by a restoration company the bills will mount up very quickly.
Old 10-01-2017, 11:35 AM
I think 3k is way too much too. 500 quid maybe.
Old 10-01-2017, 12:15 PM
charlie luciano
charlie luciano's Avatar
Go careful, that does looks fairly rotten, I paid £3800 for this one off a mate of mine, it looks in a lot better shape than the white one in question
Attached Thumbnails Capri 2.8 project - yes or no??-img_0116.jpg   Capri 2.8 project - yes or no??-img_0111.jpg   Capri 2.8 project - yes or no??-img_0114.jpg
Old 10-01-2017, 12:17 PM
XRT_si
XRT_si's Avatar
They're still £500 cars to me
But like everything old Ford related, prices for even ropey Mk3 Capris have gone mental.
http://www.ebay.co.uk/itm/1983-FORD-...YAAOSwUKxYbqdo
http://www.ebay.co.uk/itm/1983-FORD-...3D132055611074
Old 10-01-2017, 01:09 PM
Rax
Rax's Avatar
Back int day when all my mates had most of the variants and engine sizes I really didnt like Capri's .
The only one I liked was my mums mates E plate 2.8 special which she bought brand new . I always just thought as they were old hat .
strangely now as I am older I find them more appealing
Plus theres something about this one that I cant quite put my finger on . . . . . . . .
Old 10-01-2017, 01:17 PM
Adam-M
Adam-M's Avatar
Tbh if you could get a well done restored one for 10k I'd be tempted to go down that route as that white one looks like a rot box tbh.
Old 10-01-2017, 01:27 PM
charlie luciano
When I clocked the plate I thought there's someone on site with that user name
Rax (10-01-2017)
Old 10-01-2017, 02:36 PM
Rax
Rax's Avatar
I have been known as different variants over the years as Rax,Rac,Rackers,Raccers and Racus .I dont know which one is correct anymore
The closest I got before was RAC 322W on a black sunbeam I had .
charlie luciano (11-01-2017)
Old 10-01-2017, 02:44 PM
lee2cossies
lol. £500, the thing would break for easy £2k. Maybe 10 years ago, iv go a 3.0s that I paid £180 for, a 2.8 turbo 4 speed that was £1500 and is mint, a 1.6 laser that cost me £160, but that was 10+ years ago, like everything else old ford wise the prices have rocketed, £2k now gets u a ropey 1.6 laser that's just about got an mot, 2.8 rust buckets much worst than this one fetch £2k. Its a shame as capris have always been affordable in comparison with over priced mk1/2 escorts but now are getting out of reach too.
Old 10-01-2017, 02:46 PM
lee2cossies
That's a stunner, worth double what you paid now!
Old 10-01-2017, 03:26 PM
gjh
gjh's Avatar
Save it if you can! Will be a full on project mind, hopefully you can get it for a sensible amount.
Old 10-01-2017, 04:32 PM
gcfcos
gcfcos's Avatar
I used to pay peanuts for capris in the late 90s/early 2000s. Paid £150 for a 2.8i special that was seriously clean. Was happy when I got £250 for it and made £100 profit lol
Old 10-01-2017, 04:34 PM
costina
costina's Avatar
Don't i know it mate i backed out of a ebay deal wish i bought it now. That was about 3 years ago.
lee2cossies (10-01-2017)
Old 10-01-2017, 06:13 PM
TomPengelly
Kapow!!
I drove it up the road today, actually drove very well. No
noises at all really. Pulled like a train, loads of torque and very sideways on roundabouts.
It has nice history and 80,000 miles, only bad
thing on paper is 12 owners. Is that an issue?
after driving it I want it even more!!
Old 10-01-2017, 06:36 PM
rog
rog's Avatar
Depends on your budget really, how much are you willing to spend in total for a good restoration? If for example you can buy a very similar car in relatively good nick for say £5.5k I certainly wouldn't want to be paying £2k for this one, after you've thrown £3k at it it'll still need even more work, so financially it doesn't make sense. I'd pay £1200 max for this, or if he has a price start by offering him 50-60% of his number.
Old 10-01-2017, 07:00 PM
gcfcos
gcfcos's Avatar
12 owners and old fords kinda went together back in the day mate I wouldn't worry Too much about that. Have u had a look up on the ramp yet?
Old 10-01-2017, 07:12 PM
TomPengelly
Kapow!!
Not yet, taking it on Thursday.
Old 10-01-2017, 09:38 PM
cossynut2
cossynut2's Avatar
So the engine and gearbox seem strong which is good. If you dont have to spend money on a rebuild that would save a lot of money. Once you get it up on the ramp you should be able to see exactly how bad the rust is and make your mind up what you want to do.
You were game driving it hard around some roundabouts, with the amount of rot in the bodywork rather you than me!!
Old 11-01-2017, 03:05 PM
TomPengelly
Kapow!!
I didn't say I drove it hard. It lost traction at 10-15mph...
