Rocker cover gasket advice.
Old 22-09-2015, 11:51 AM
Brickhouse
Brickhouse's Avatar
Default Rocker cover gasket advice.
Excuse me if I sound a bit thick here! Would a rocker cover gasket be under more stress thus more likely to leak oil if a car is driven fast/hard through the gears?
Old 22-09-2015, 12:39 PM
Moderator
STeve's Avatar
if the car is running at maximum heat where the oil is thinner gasket failure would normally fail due to its age or OTT extreme heat or simply poorly torqued
Brickhouse (22-09-2015)
Old 22-09-2015, 12:43 PM
Brickhouse
Brickhouse's Avatar
Thanks mate
Trying to work out why my 2003 Mondeo V6 2.5 is leaking oil from what I believe to be the rocker cover gasket.....Strange thing is when she is driven with ease there is no oil leak, hard driving and when I pull up smoke is coming from the back of the engine that smells of oil which makes me think it must be the rocker cover on the back part?
Old 22-09-2015, 01:32 PM
Bailes1992
Bailes1992's Avatar
The oil will be hotter and thinner when the engine is driven hard. At high revs it will be throwing a lot more oil around too.
Old 22-09-2015, 03:07 PM
cossiestu
cossiestu's Avatar
Maybe also an issue with a blocked breather and its pressurising the rocker box?
Old 22-09-2015, 03:10 PM
Brickhouse
Brickhouse's Avatar
Thanks for the help. I have just had my car up on a trolley jack and the back of this V6 engine looks dry......Confused where this oil smoke is coming from now as coming from the back of the engine when driven hard
Old 22-09-2015, 10:58 PM
cossiestu
cossiestu's Avatar
Just an idea, but staying with the breather theory, is there a breather pipe/filter etc with a split in it, which, with a bit of pressure, it's letting fumes/smoke out, but looking ok at first glance?
...I've no idea with V6 Mondeo's, so if I'm talking out my arse, feel free to say!!
Old 22-09-2015, 11:30 PM
Brickhouse
Brickhouse's Avatar
Thanks Stu.....Going to be on missions tomorrow looking at breather pipes
Your Cossie in your picture.....Amazing bud, love the colour, wheels and height
Old 23-09-2015, 06:28 AM
cossiestu
cossiestu's Avatar
Good luck with it, hope you can sort it, but only guessing....
Thanks, the wheels are black at the moment, much to a few people's dislike! lol
Mark RS
05-03-2021 06:08 PM
01-11-2015 06:53 PM
Mc5506
05-10-2015 09:57 PM
deathrider666
28-09-2015 06:12 PM
Quick Reply: Rocker cover gasket advice.
