Burton oil pump
Old 26-08-2015, 09:28 AM
Adam-M
Adam-M's Avatar
Default Burton oil pump
Hi chaps my 4x4 saff engine has a burton power HP oil pump fitted and has been since the engine was built 9k ago. One of my mates told me he was advised not to fit one of burtons pumps to his cossie as they are shite so I did abit of googling and it seems there is a lot of bad reviews of these.
I have an oil pressure gauge and with my remote filter housing and oil cooler I'm getting about 20psi oil pressure on hot idle, to be exact it may be 22psi. It's pretty high when cold I'd say about 60-70psi. This is with millers cfs 10-60.
Should I remove the oil pump and fit another or is there nothing to worry about? I'm abit paranoid now chaps lol.
Also is there an alternative pump that is pretty reliable? I have the original pump so could maybe get that rebuilt.
Adam
Old 26-08-2015, 09:30 AM
Adam-M
Adam-M's Avatar
I don't know where my pressure gauge is getting its feed from I'd imagine it would be the usual way with a yb.
Old 26-08-2015, 09:45 AM
Jay,
Sponsor
Jay,'s Avatar
I never see the need to fit a high pressure pump unless you do the supporting mods to get the oil back to the sump quick as its the drain back thats slow but if thats the readings your getting it sounds fine sound be around 2.4 bar at a cruising speed . I do remember a few years ago there was some iffy pumps doing the rounds but have not heard anything for a good while
Old 26-08-2015, 09:48 AM
Adam-M
Adam-M's Avatar
Hi jay thanks for the reply mate, well the full engine was rebuilt mate so I think he replaced the pump to a new HP one just for peace of mind. I have a receipt somewhere I think it was bought around 2010 mate. My racetech gauge only reads in psi, iirc cruising at 40/50mph I will see about 40psi pressure and it doesn't drop on boost which I suppose is reassuring
Old 26-08-2015, 09:51 AM
Jay,
Sponsor
Jay,'s Avatar
Well thats about 2.7 bar so thats fine and you should see around 60-70 psi tapped out but remember oil p will change dependent on make of oil and grade
Old 26-08-2015, 10:04 AM
Adam-M
Adam-M's Avatar
Next time I'm out jay I'll see what the pressure is when flat out at 6k revs ect, doubt it's as high as 60psi tho lol
Old 26-08-2015, 05:37 PM
bigdel
bigdel's Avatar
Just had a Burton pump fitted in mine. Shows about 75psi at tickover (reading taken when the engine was first fitted)
Nopt got a pressure gauge fitted so don't know what it does when the car's moving thought
Old 26-08-2015, 05:39 PM
Adam-M
Adam-M's Avatar
I know mines will have slightly less pressure due to my oil cooler kit just didn't know what was normal pressure on a cosworth both warm and cold. Fingers crossed our pumps are alright mate lol
Old 26-08-2015, 05:47 PM
Jay,
Sponsor
Jay,'s Avatar
Shouldn't loose pressure because of a oil cooler kit Adam as it don't know how much oil its pumping it just pumps
Old 26-08-2015, 05:51 PM
Adam-M
Adam-M's Avatar
Aww ok mate, I read that pressure loss of up to 8psi was common due to the extra volume the pump has to fill is that not the case?
Old 26-08-2015, 05:53 PM
Jay,
Sponsor
Jay,'s Avatar
Shouldn't be mate it will take a tad longer to build pressure
155lee
27-10-2015 04:55 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
oilman
Trader Parts for Sale.
23-09-2015 07:32 PM
Eigdoog
48
19-09-2015 11:03 AM
Rich Coveney
Ford Mondeo Including ST
15-09-2015 05:39 PM
Quick Reply: Burton oil pump
