View Poll Results: ARE YOU INTERESTED IN
PUMP COMPLETE
55.56%
IMPELLER ONLY
44.44%
Voters: 9. You may not vote on this poll
blacktop zetec reversed water pump market reserch
reversed
standard
Market research
Hi all just to give me an idea of numbers I've decided to do a little research so please help if you can.
If you would be interested in a reversed ( I.E. clockwise running direction ) blacktop zetec water pump complete or an impeller please use the poll above this post.
the impeller will be about £20 and the water pump around £60, this is not a definite price!
I will be posting this on every forum that I can so please only reply once!!!
many thanks and a happy new year to everyone.
Ivan
reversed
standard
Market research
Ivan
james kiely (01-01-2015)
id say yes i take it that idler pulley is a afteemarket adition ?
the main reason is normally alternator location.. on both 2.0 silvertops and blacktops from the factory there rear mounted.. on a silvertop its a easy swap as the 1.6/1.8 in the fiesta's/escorts has from mounted alternators so the 1.6/1.8 water pump was revised to spin the other way.. on blacktops there isnt this option. rear mounted alternators are a pain to use on say a fiesta/escort due to room
Yes stu your set up is right. All the reverse pump does is do away with the top pulley so you can run the belt over the water pump and down to the alternator
studabear (02-01-2015)
Sorry for the delay.
http://shop.autospeed.co.uk/index.ph...product_id=239
They have started using blacktop zetec in stockcars, as they run no alternator the reverse impeller is needed. If you look you will see a picture of the imppeller, they do the extra idler setup also. Hope this helps.
ivorbigun (16-01-2015)
