after some advise
after some advise
1st off all the best every 1 .
i have just been gettin my 1st cosworth , 4x4 sapphire in flint grey
the car is standard bar a filter and exhaust .
am after a bit more power , 300ish bhp for now because the cossie isnt as fast as the old t5r it replaced .
the standard t3 turbo seems to be in really good nick so want to use that before i need to replace it . but eventualy i will want more power and dont want to buy greens , greys then blacks etc so would the 55lbs blacks be okay on a t3 stage 3 set up
cheers
cheers
thanks bud , just a wasnt to sure the blacks wernt goin to be to much on the t3 , what the spec of your car , 12sec quarters is good going
will the injectors not be maxed out with that conversion , plus i want to get to know the car before goin daft with bigger turbos etc
no worrys wrongrs
cheers
no worrys wrongrs
cheers
The NMW gunship uses the standard injectors and turbo. Think its mapped for higher boost, in the mid range and tails off at higher rpm. Supposed to be an awesome setup. Im just running an MSD stage 1 at around 280bhp and its smooth and quick.
Gunship is only really advisable on a good engine from what i gather, but i think by that it means that the 300bhp is only possible on an engine thats 100%.
Personally i'd put 55lbs injectors in it and get it live mapped.
I run this MSD stage 1, mint setup!
Thanks lads. Any 1 use the stage 1 set up from norris. What sort of prices are the stage 1 set up. The car has the blue injectors in already with it been a 4x4.
DixieTheKid
11
06-06-2020 11:20 AM
massivewangers
30
01-10-2015 07:40 PM
Andypandy260
23-09-2015 10:28 PM
dange
Ford Mondeo Including ST
23-09-2015 12:11 PM
