mt75 gearbox query
Rubber Rhino Crew
mt75 gearbox query
hi guys just wanted to confirm that the mt75 4x4 box out of a 2.0 dohc xr4x4 will fit the Yb engine and is the same box as the sapphy and escos.
I know the 2.8/9's had a different bolt spacing on the gearbox but i think the 2.0 dohc engine has same as a cossie....
So just for peace of mind as i'm thinking of buying one...and the bellhousings are integral so i need to be sure
CheeRS
Dan
CheeRS
Dan
Rubber Rhino Crew
well in that case i have just brought a good condition 4x4 cossie box for 50 quid...
was listed on ebay as a xr4x4 2.0 dohc box (v6 version of the xr4x4 has diff box but the 2.0 is same as cossie ) is local too
CheeRS
Dan
CheeRS
Dan
Originally Posted by a.k.a
You need to make a few simple changes to it in order for it to be mated to a cosworth
You will need the clutch release arm from a cosworth - Ford still supply them new for Ł20 also you need to replace the lug in the bell housing to which the release arm connects, to a cosworth version - again available from Ford for a fiver -just tap it out and replace
If you dont do this then the clutch wont engage as the travel is different on the 2 litre version as the flywheel is thicker
This I found out the hard way but box has been good as gold for a couple of years now and was a lot cheaper without the dreaded cosworth word
Rubber Rhino Crew
yeah i have just gotten hold of a low mileage 2.0 dohc and i brought a box for 50 quid a week ago... so i now have a spare....
Trouble is ford no longer do the pivot part i need to convert them to cosworth clutch fork (they do the fork and bolt but not the pivot piece :S)
Any ideas guys? or i'll end up having to have a couple made if anyones interested?
CheeRS
Dan
CheeRS
Dan
chowfornow
14
05-01-2019 09:01 PM
