What brake horse is ur Cosworth? Please contribute.
Not a competition lads, but think this will be a very helpfull topic.
list every engine mod, and brake horse and torque figures. From rolling road graph. from 220 bhp on yellows, to 500 or 600bhp. Please Contribute.
Currently on yellows it is 279bhp with 261 torque. undergoin engine rebuild at present. have my greens and map sensor all ready.
Running 17psi off boost.
low comp pistons.
pts stage 2 turbo, dont really no what it is?
Filter an excaust.
Chip.
low comp pistons.
Filter an excaust.
Chip.
Good topic....
Had mine dynoed bout 3 weeks after I bought it with the mods that the prev owner had done. Sort of a "starting point" for me.
3dr running stage 3... pod filter, 3inch hi-flow exhaust, turbosmart boost adjust valve, greens, 3 bar map sensor, .31 actuator, stage 3 chip, wrc head gasket, grp a coil and leads etc etc..
Was quite dissapointed with the results when I saw the numbers (at the wheels btw) but after seeing the graph!!! Easy to see its the boost that is the problem!! It dives off faster than it climbs! Have since purchased a Apexi AVC-R Electronic boost controller. Will have it back on the dyno once it sorted... stay tuned
280bhp not sure on torque figure. running stage 1 karl norris gunship chip. standard 4x4 dark blue injectors. roose sport silicone hoses, standard T3 running 22psi at peak drops to 15psi. not to sure on figures as only had the car a month.
344bhp and 331 lb of torque.....
low comp bottom end
T34/.48 housing/ -31
greens
3 bar map
500 cooler
BD10 inlet and standard exhaust cam
22psi
mongoose
k&n induction kit
set up by Paul Hills at engine advantages
low comp bottom end
greens
3 bar map
500 cooler
22psi
mongoose
k&n induction kit
what boost nice head, like to no what boost, cos understand it better.
Tangoldsierra, I am from south yorkshire too, sheffield, what was the details on that build boost etc, thats what aiming 4.
Lamalammalammylama, gud figure for boost, what drivability like?
whats a t38 mate. mine is a stage 2 with 360 mashings, from pts supposed to handle 26psi. so what is mine???
Tangoldsierra, didnt say were abouts? and how mutch, wnt to park ex??
aka Turbosailorboy
lamylama, what else u done to engine, breather?swirl pot? how mutch was turbo and what damper u use?
I have a grp A breather system with oil seperator tank,swirl pot,turbo was already on the car when i brought it but has 360 deg bearing,cut back blades etc and i run it with a bailey turbo damper.Car has been very reliable too....touch wood!!!!!
Our 3dr is 390 bhp with 353lbs of torque running 24lbs of boost
7.6.1 C/R
200 Motorsport Block
Light Blue Injectors
T34/.48
GGR Group A Dump Valve & Group A Air Filter
Mongoose Exhaust
Swirl Pot, Oil Seperator & Breather by MLDevelopments
Silicon hoses by Roose
Pro-Alloy RS 500 Intercooler
Built by Harvey Gibbs
R/R at Powerstation in Tewkesbury
7.6.1 C/R
T34/.48
Mongoose Exhaust
MY SPEC AS BUILT BY STEVE SCOTT LAST WEEK
200 LONG STUDDED BLOCK
BD10 BD14
LOW COMP
TRIPLE LAYER HEAD GASKET
SIEMEN INJECTORS 660CC
T38 TURBO
500 COOLER
REBUILT HEAD
HI PRESURE PUMP
STEVE HAS SAID LAST 1 HE BUILT TO THIS SPEC DONE AROUND 450BHP AND 420 POUNDS OF TORUQE SO IF ITS ANYWHERE NEAR THAT I WILL BE HAPPY
BD10 BD14
LOW COMP
T38 TURBO
500 COOLER
REBUILT HEAD
HI PRESURE PUMP
94,ooo mile 4x4 engine only been apart for a grpA headgasket no other mods done to the motor
Greens
3 bar
500 cooler
T-34 .48
Set up by Mark @ M.A.D Made 349bhp and 355lb/ft @1.6 bar at Interpro
Greens
3 bar
500 cooler
T-34 .48
Ive got a moonstone blue saff 4x4. Had it set up and dynoed at Well Lane. Its running 327bhp with 296ftlb of torque. It was in last months Fast Ford rolling road day with the Manchester RSOC Group. Onlydynoed at 317 as i was the first on the rollers
Last time i had my 3dr on rollers it made 312bhp and 321 ft/lbs
Standard T3
Greens
K&N cone filter
Mongoose exhaust
4x4 cooler
Ahmed bajoo chip
21 psi peak holding 19psi.
Going back on saturday to see what difference its made with Greys,Pro alloy 500 cooler,T34.55 and NMS live map
Standard T3
Greens
K&N cone filter
Mongoose exhaust
4x4 cooler
Ahmed bajoo chip
mines
262bhp 14psi
stage1 chip
zorst
K&N
thats it
got a boosting prob at the mo, going to NMS for the gunshop conversion as soon as i get some more cash together
262bhp 14psi
stage1 chip
zorst
K&N
thats it
406 bhp and 428 lb ft torque
T34,.63,
Greys live mapped by MSD on L8 ECU,
BD10's,
Ported/polished head by Bluesprint,
Lightened balanced bottom end,
Long studded 200 block,
WRC gasket,
GGR Boost hoses,
A&H 500 size cooler.
T34,.63,
BD10's,
WRC gasket,
GGR Boost hoses,
some nice engines on here .well ive got a rear wheel drive escos running around 420bhp on rs500 plenum t4 turbo 200 block 8 greens bd14 inlet at 25 psi good fun and handles better than any saph or 3door iv had infact i love it and im turning it into a bit of a beast over the winter so keep your eyes open for next year.iv got my moonstone 500 in the garage wich has got genuine 500 block long studded low comp lightened and balacend bottom end ported head bd14s 8 greens t4 turbo pectel loom and ecu runs 511 hp and 452 lb ft.then iv got my saph race car that runs 592 bhp it has long studded 200 block spray jets low comp pistons heat treated shot peened rods f1 conrod bolts lightwieght crank line port big port head isky valve springs bd16 inlet bd14 eexhaust 8 greys on 500 plenum and turbonetics t66 turbo running 2.2 bar
Location: learnin to build a yb lump properly in dennis's garage
low comp bottom end
greens
3 bar map
500 cooler
22psi
mongoose
k&n induction kit
low comp bottom end
greens
3 bar map
500 cooler
22psi
mongoose
k&n induction kit
current car i dunno bout 125 bhp 90lb/ft nah im guessin 260 ish not gonna bother dyno ing this enf=gine will wait till my new ones built id then expect in the region of 360/400 bhp plenty for a rwd
i have a 3 door, with 200 engine, gt 35 bb turbo, spcial spec cams, ported, S/S ex. manifoil with sep wg, tial 46mm, big pro spec intercooler, H-con rods, polished and nitril hardened crank-shaft . acralite wrc pistons, arp bolts, autronic ecu++++
600 bhp + -
600 bhp + -
Tottalley not sure as i dont know what chip is in it before i taken it off the road but i do know it has a 3bar map sensor, greens, standard t3 not sure what actuator and boost as only running standard gauge to !!! maybe as a guestimate 280 ish tottalley not sure !!!!
Hope to be running about 330-350 next year as work and pennys permit !!
Went to see engine builder last night, and all the bottom ends in, but after towing it a mile down road, to put head on,on bore number one, a pin head hole has apeared in the liner. midway up, something to do with the casting of the liner,,,, gutted prob be another month now, oh well.
