would a st170 head fit my silver top zetec?
would a st170 head fit my silver top zetec? 97 mondy
as to get hold of a st170 head would be alot easier and cheaper than to moddify the std head
i know that the st170 have bigger valves and ports,i know that the head runs vvt and solid tappets etc
i cant remember if the engine is belt drive or chain driven as this will be a problem,would the std st170 cam gear mate up with the silver top stuff ?
just need to know if this will work?
has anyone done this conversion yet ?
i know i would see some good gains in power if this works
Colossal Pervert
It will bolt on. You'll need to do a custom belt tensioner arrangement. There's the VVT to consider too, but if you're smart you can block it off and get a normal cam pulley to fit (with an adapter).
so the head fits the silver top block cool
what is envolved with the tens/pulley set up ?as it is a custom set up needed
how does the the vvt work on the st is it driven off the cams or the inlet set up
what modification is need to bypass it etc
would the vvt work with throttle bodies or not etc
heres a pic of the timing belt set-up
It works by letting oil pressure into a vairiable inlet pulley, and advancing the timing to improve bhp, yeah u can run it with bodies, just all depends if ur mangament can do this.....
hmm
swear i have seen a a silver top motor running a st170 head in a red rs tubo which didn't have any problems with the water pump issues
Bodybuilding
Location: Cannot be identified by the information given.
Thought it was the timing belt set-up u needed?
Realy it just cut and one of the top holes drilled bigger, then spaced away from the block 20mm and the tensioner turned.
JoeyBoyden
04-01-2024 02:36 PM
marky_g
15-08-2015 10:43 AM
track.focus'd
12-08-2015 05:53 PM
