Rebuild
Old Feb 2, 2006 | 03:27 PM
Moonstone Kev's Avatar
Moonstone Kev
Default Rebuild
Wot do tuners mean when they say do you want a short engine build?
Old Feb 2, 2006 | 03:34 PM
Dave Henshall's Avatar
Dave Henshall
basically, just the blockand head - so rebore, new pistons and rings, reground crank and shells, head skim, and new valve guides and regrind.
basically a freshenup of the major components only - so a short motor exhange would be - you unbolt all your ancillaries from your engine (manifolds, turbo, injectors, sensors etc) and swap them onto the new engine.
Old Feb 2, 2006 | 04:45 PM
Alvyn's Avatar
Alvyn
Default Re: Rebuild
I'd take that to mean the bottom end ONLY ie they rebuild the block(pistons,rings mains and b/ends etc!
Old Feb 3, 2006 | 07:03 AM
HORNETS7's Avatar
HORNETS7
it is as already said just a rebuild of the complete bottom end
should include
rebore
new pistons & rings
crank regrind new big end and main bearings
new oil pump
new oil seals and crank seals!
Old Feb 3, 2006 | 08:34 AM
Stu @ M Developments's Avatar
PassionFords Creator
Short engine is the block and all components internall to the block.
Head is NOT done.
Old Feb 3, 2006 | 08:39 AM
Dave Henshall
Old Feb 3, 2006 | 09:59 AM
Moonstone Kev
Default Engine build
What would be the cost of short engine rebuild & to recon the head.
bobsworth
77
Mar 24, 2016 09:30 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Mc5506
Oct 5, 2015 09:57 PM
coscor86
Sep 20, 2015 01:21 PM
