Flickering Cossie Battery Light
Old Jan 21, 2006 | 01:40 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default Flickering Cossie Battery Light
2wd cossie, light flickers from time to time, not constant.
Apart from the wire from the light to the alternator, what else should I look for ?
Thanks
Old Jan 21, 2006 | 01:42 PM
rapidcossie's Avatar
rapidcossie
dodgy alternator?
is the terminal tight onto the battery?
Old Jan 21, 2006 | 01:51 PM
frog's Avatar
frog
Not checked anything yet, just wondering what else I should be looking for when I pop the bonnet.
-Alternator could be on its way out, but I would expect the light to glow rather than flicker, it physically goes on and off...
Old Jan 21, 2006 | 02:20 PM
KSA-Cossie's Avatar
KSA-Cossie
Slack belt ?
Old Jan 21, 2006 | 06:53 PM
Alvyn's Avatar
Alvyn
my saff battery light on dash some times came on very dimly and if I tapped the top of the dash it went out till the next time, IT was the plug that goes into the back of the clocks one of the wires was loose in the muti plug so NOT always making a good connection!
Old Jan 21, 2006 | 09:50 PM
frog's Avatar
frog
OK, thanks guys, will have a look at all this tomorrow
Old Jan 21, 2006 | 11:32 PM
rsnissan's Avatar
rsnissan
voltage regulator is worth a look too
Old Jan 22, 2006 | 02:34 PM
frog's Avatar
frog
Been and had a look, it's all fixed, so here's another one for the list...
The charging wire from the alternator back to the battery had come loose off the connector
I reckon it's actually gradually broken off as the wires looked rusty when I peeled the insulator off.
Worst, the insulator was all burnt, either because it had been touching the alternator case and shorting to ground, or, due to the heat from the exhaust manifold
Anyway, brand spanking new red cable now in place
Thanks for your helps lads
Old Jan 22, 2006 | 02:43 PM
KSA-Cossie's Avatar
KSA-Cossie
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
