welding
Old Jan 19, 2006 | 04:15 PM
rapidcossie's Avatar
rapidcossie
Default welding
how hard is it to weld sttel to alloy??
cheers
euan
Old Jan 19, 2006 | 04:27 PM
Grahamxx's Avatar
Grahamxx
I'm afraid you can't.
You use AC current to weld aluminium, and DC current to weld stainless steel/mild steel. The only time you can weld aluminium using DC current is when the material is as thinner as a news paper.
Filler rod would also be a problem.....
Old Jan 19, 2006 | 04:54 PM
rapidcossie
its just my quick shift snapped and it needs welding.
its alloy and steel and was welded by the maufacurer so it must be possible or i must have something wrong??
Old Jan 19, 2006 | 04:56 PM
rapidcossie
graham...could you look at this thread...
it clearly shows the bits that need welded.
the rod and lever need weleded onto the top of the gearbox.
the 4 holes are the bits that have snapped
Old Jan 19, 2006 | 07:03 PM
Grahamxx's Avatar
Grahamxx
Do you have a picture of the item?
Old Jan 19, 2006 | 07:04 PM
cocaina_xr2i's Avatar
cocaina_xr2i
wrench it all
you can weld it but you would need to do a plasma weld to make the metals to stick together thats the only way but yes it is possible
Old Jan 20, 2006 | 12:09 AM
Azrael's Avatar
Azrael
Evo VIIIMR roof is welded so I think (apart from beeing rivetted).
Old Jan 20, 2006 | 09:45 AM
cocaina_xr2i
wrench it all
saorry mate but I don't have a clue about evos
boeb
Jan 9, 2020 05:11 AM
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
