Lucas&bosch dizzys help needed
Old Jan 14, 2006 | 12:19 PM
turbo.jon's Avatar
turbo.jon
Default Lucas&bosch dizzys help needed
Me old mans got a problem with his car a 1.4 carb cvh orion its got no spark we have changed the coil twice with 2 we no that are good but it didnt sort it out only thing i can think is its the distributor is fooked we have been down scrappy but they only have the lucas dizzy and not the bosch one which we need
can you use either one of these or do you have to use the one thats originaly fitted to car???
cheers
jon
Old Jan 14, 2006 | 12:52 PM
jonnyturbo's Avatar
jonnyturbo
pretty sure you can use either mate
Old Jan 14, 2006 | 01:16 PM
RickRS1976's Avatar
RickRS1976
Try changing rotor arm first! and dizzy cap, make sure that plugs are not failed up, and the dizzy normally has an electronic part on it which packs up, cant remember what is called a module.
Old Jan 14, 2006 | 05:25 PM
Phil DJ's Avatar
Phil DJ
Ignition module i think it's called. I'd try dizzy cap and rotor arm as well
Old Jan 14, 2006 | 08:29 PM
HORNETS7's Avatar
HORNETS7
as above it will be your ignition amplifier !
black thingy attached to the dizzy where the plug clips to !
Old Jan 15, 2006 | 03:55 PM
turbo.jon's Avatar
turbo.jon
Its deff got to be the dizzy but cant get hold of the bosch one can get loads lucas ones just need no if there diffrent plugs on them as every thing else should be ok any one no???
cheers
jon
Old Jan 15, 2006 | 04:37 PM
Phil DJ's Avatar
Phil DJ
I can't see why they would be diffrent as they're for the same engine.
I'd just try it and see. If it's the wrong one then u could sell it on ebay for more than u paid for it
Old Jan 15, 2006 | 05:06 PM
RickRS1976's Avatar
RickRS1976
Take you old one with you if you are going to the breakers and compare it.
Old Jan 15, 2006 | 05:14 PM
SafeChav's Avatar
SafeChav
I reckon.....you should try gettin the igniton module on it tested
Bet you a jam tart the igniton module has gone
(black box on the dizzy and has a 3 pin wiring plug, know what i mean?)
Oh and if you do need a new dizzy or anything, i can probably source you one
Old Jan 16, 2006 | 05:52 AM
RickRS1976's Avatar
RickRS1976
thats what i said straight away safechav as they are prone to this
Old Jan 16, 2006 | 01:39 PM
turbo.jon's Avatar
turbo.jon
Its sorted he tried the lucas dizzy and it fitted the same and fired up first time
thanks everyone
Old Jan 16, 2006 | 02:20 PM
SafeChav's Avatar
SafeChav
beckham sorry i missed that
At least he's sorted it
SmudgerByName
52
Jul 28, 2016 06:14 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Roosie
Aug 15, 2015 08:09 PM
yawiejon
15
Aug 9, 2015 06:36 PM
col93saphcos
Aug 7, 2015 03:21 PM
