cozzy tick over problem
Old Jan 10, 2006 | 07:02 PM
ste serg's Avatar
ste serg
Default cozzy tick over problem
About a month ago my saffs tick over has risen to around 1100 rpm from 850ish.
Ive cleaned and checked the plugs dizzy cap etc and have adjusted the screw under the thottle body,but it still the revs wont go down enough.
any thoughts?
Old Jan 10, 2006 | 07:37 PM
ellicoss's Avatar
ellicoss
Hello mate take the idol valve out and give it a good clean with wd40 that will sort it mate
Old Jan 10, 2006 | 08:32 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Possible air leak on inlet side. check all your connections
Old Jan 10, 2006 | 10:02 PM
dave cos4x4's Avatar
dave cos4x4
Hi Ste,
iscv on the throttle body.
unscrew the 2 screws and pull it off,really hard to pull off as it may be stuck on.
good clean with wd 40 and should be ok.
if not, about Ł80 for a new one.
oh, try unplugging it first, it will idle perfect as long as you have not turned the idle screw too much.
Old Jan 11, 2006 | 07:16 AM
ste serg's Avatar
ste serg
cheers people ive tried the iscv and made no difference it must be an air leak some where i guess?
cheers...
Old Jan 11, 2006 | 08:11 PM
vyper developments's Avatar
vyper developments
Hi Mate,
Also worth checking the breather pipe from cranckase oil seperator these can sometimes split and suck in air past the non return valve on the bottom of the the plenum chamber.
Mike.
DAZZER
Sep 30, 2015 08:43 PM
Fiddy
21
Sep 29, 2015 06:10 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
