2wd sapphire cold running problems
Old Jul 17, 2004 | 12:47 PM
mike77cos's Avatar
mike77cos
Default 2wd sapphire cold running problems
I have a 2wd sapphire cos and first thing in the morning it starts fine, after a second or two it starts to missfire and appears to over fuel, while like this if you try to drive it, it will stall and be a sod to re start, if you leave it to tick over for 10mins it will be ok, but it still feels slightly flat. she is running yellow injectors unknown chip, low compression pistons stg 2 hybrid turbo. all the sensors appear to check out ok and the amal valve is working. The only thing I haven't changed is the ecu, although I have tried a chip. has anyone got any ideas.
Also does anyone know where you can get a new engine loom, and roughly how much, as my car is the one that caught fire at castle coombe on the 10th of july, and although running just the same as before, it could do with a new loom.
Old Jul 20, 2004 | 05:39 PM
mike77cos's Avatar
mike77cos
Please help! Somebody?
Old Jul 20, 2004 | 05:47 PM
rocar's Avatar
rocar
Try another fuel regulator and set the fuel pressure.
Roger
Old Jul 20, 2004 | 06:01 PM
mike77cos's Avatar
mike77cos
I have set the fuel pressure, and that seams to be fine! After some more investigation, it
only seams to be number 1 cylinder, I have checked the compressions and they are all close to each other ( They are low, but it has low comp pistons). I'm running out of ideas, and cornwall is so far from any good specialists!
Old Jul 20, 2004 | 06:12 PM
rocar's Avatar
rocar
Try disconnecting the vacuum pipe from the regulator,you might have a hole in the diaphram so the engine will suck fuel from the vacuum pipe.
Roger
Old Jul 20, 2004 | 06:33 PM
Dave McB's Avatar
Dave McB
Is there not a cold start sensor on a Cos?
If so, could it be that?
Old Jul 20, 2004 | 06:53 PM
mike77cos's Avatar
mike77cos
I'll have to try another pressure regulator, I think the cold start is controlled by the ecu, but I don't think that would explain missing on one cylinder, i've tried plugs and change the injectors ( that caused the fire at castle coombe).
Old Jul 20, 2004 | 07:00 PM
rocar's Avatar
rocar
If you think that the problem is on No:1 clyinder then try,disconnect the injector plug No:1 and start the engine on 3 clyinders and it should keep running.
Roger
Old Sep 12, 2004 | 09:40 PM
blaazer2's Avatar
blaazer2
I DONT SUPPOSE YOU MIXED ONE OF THE INJECTOR PLUGS UP WITH SOMETHING ELSE? ....I DID IT ONCE
Old Sep 15, 2004 | 06:43 PM
mike77cos's Avatar
mike77cos
No I don't think so, i'm triying another ecu as soon as it turns up! Still not sure though!
Old Sep 24, 2004 | 05:01 PM
mike77cos's Avatar
mike77cos
Ok up date on what i've tried, air temp sensor coolant temp sensor, had engine rebuild, a chip, complete ecu, injectors, map sensor, dizzy phase sensor, new leads, dizzy cap, rotor arm, fuel presure regulator, fuel pump, filter, fuel pipes and I still can't get the b*tch to cold start properly, it still over fuels and misses from cold, enough fuel to start filling the sump with fuel! when warm she runs fine and like sh*t off a shovel, Has anyone got any Ideas! pleeeeeeeeeaaaaaaaaassssssssseeeeeee
Old Sep 24, 2004 | 06:24 PM
doff21's Avatar
doff21
funny that i am having the same problem
Old Sep 24, 2004 | 08:49 PM
abdr500's Avatar
abdr500
sounds like you map sensor you should have look ther first that first
Old Sep 25, 2004 | 11:51 AM
mike77cos's Avatar
mike77cos
I've tried one new map sensor and the wiring seams fine!
Old Sep 25, 2004 | 12:22 PM
rocar's Avatar
rocar
You should try a wiring harness,I had one with such problem once and it was the loom.
Roger
Old Sep 25, 2004 | 03:52 PM
mike77cos's Avatar
mike77cos
I would love to try a loom, looking at plenty of second hand ones on ebay, but would rather fit new, but you can't get from ford any more, anyone got any ideas where to get one from! I'll try anything now.....
I wouldn't think you would have cold start problems in Malta Roger!
Old Sep 28, 2004 | 04:08 AM
rocar's Avatar
rocar
I think Burton have them new.Check on there website www.burtonpower.com
Roger
Old Sep 28, 2004 | 09:28 PM
doff21's Avatar
doff21
pj motorsport do them 529 quid m8
Old Sep 29, 2004 | 06:42 AM
Stu @ M Developments's Avatar
PassionFords Creator
You really need to get this car onto a Pectel monitor to be honest fella...
Incidentally, your not using Champion C57s are you?
Old Sep 29, 2004 | 07:05 AM
pugo's Avatar
pugo
Stu,
I have this problem and am using c57s, is there a problem with them as mine runs like a bucket of poo when cold and am following this thread with interest!!!
Pugo
Old Oct 1, 2004 | 07:04 AM
Ive seen various engines with C57's that, inexplicably, wont run very well at all unless under decent load... im unsure myself what causes this but the important thing is, i know a different set of plugs cures it.
We do some decent Motorcraft plugs that run very well indeed up to 400bhp and for less cash too
Old Oct 1, 2004 | 10:36 AM
666monkey's Avatar
666monkey
I had C57's and my car idled like a pissed donkey.....
Old Oct 2, 2004 | 06:02 AM
pugo's Avatar
pugo
well as soon as i get my hands on a t4 i am hoping to make in excess of 400hp, what plugs do you recommend trying??????
if they are m/craft ones pm me as an x fmc employee, i still get the 40%dicount on plugs!!!!!
pugo
Old Oct 2, 2004 | 03:12 PM
mike77cos's Avatar
mike77cos
Mine keeps going through plugs, I thought its just because its over fueling when cold! At the moment i've got NGK platinums in her.
This will sound thick but whats a pectel monitor?
Old Oct 6, 2004 | 09:18 PM
Jake_N's Avatar
Jake_N
I`ve got the same problem . It used to have NGK R`s , but now c59c`s and its worse
Funny that sometimes it runs decent , but sometimes it missfires like hell .
It`s worse when cold .
Old Oct 7, 2004 | 09:53 AM
mike77cos's Avatar
mike77cos
I'm pulling my hair out!
Old Oct 13, 2004 | 12:26 AM
Jake_N's Avatar
Jake_N
Sorted the problem . air temp semsor was faulty
Old Oct 13, 2004 | 08:58 AM
Old Oct 13, 2004 | 05:56 PM
mike77cos's Avatar
mike77cos
I'm still trying
jason_nike
Aug 18, 2019 10:53 AM
The Enigma
13
Aug 20, 2015 09:38 PM
markk
18
Aug 17, 2015 05:19 AM
Archiejay
Aug 12, 2015 12:07 PM
Old ford
Jul 31, 2015 06:50 AM
