Misfire Before Boost on ERST
Old Jan 5, 2006 | 06:43 AM
originalcabbie's Avatar
originalcabbie
Default Misfire Before Boost on ERST
Gent/Ladies,
I have been having problems with my ERST for months now and I thought I had finally sorted all the running problems.
Last night after a hard day at work, I was driving home when a car fucked me off by stopping with no warning in front of me so I stopped the car, flicked the bird and booted it off.
High revs, wheel spin it was all good, UNTIL I got to a roundabout and my problems have started. Under low boost or no boost I have a missfire. It is slight but the engine is hesitant unitl you get onto the turbo. When I got the car home I checked air pipes had a little look at the dizzy etc. (in the dark) and everything seemed fine. I took the car out this morning and the miss seemed better when the car was cold but still there but as soon as it got hot it seemed to get worse.
I am on ebay right now looking for dizzy, new cap, rotor arm, leads (plugs are only 4 weeks old)
ANYBODY HAVE ANY IDEAS???????
Also if you live in the Birmingham area, are there any good tuners about as it needs proper setting up aswell.
Regards
Rob
Old Jan 5, 2006 | 07:36 AM
fiestar5t's Avatar
fiestar5t
where about in birmingham are you mate ?? i know a couple of tuners that could help you out
Old Jan 5, 2006 | 01:46 PM
originalcabbie
I am just near sutton colfeild in the Kingstanding area. Car needs a good set up and this problem fixed. if you got anyone give us a number or summat if you know of any good ones.
Old Jan 6, 2006 | 10:46 PM
NEO™®©'s Avatar
NEO™®©
sounds like leads or coil breaking down as they get worse when hot hth
Old Jan 9, 2006 | 05:18 PM
fiestar5t's Avatar
fiestar5t
HI MATE GOT A FEW THE OTHER SIDE OF BIRMINGHAM FOR YOU BOTH VERY GOOD, HI-TECH MOTOR SPORT, CRADLEY HEATH, ON 01384561777 AND ALDON ATOMOTIVE, BRIERLEY HILL 01384 572 553, HOPE THIS HELP MATE, THINK ITS A BOUT 20MINS FROM WHERE YOU ARE MATE? LET ME KNOW HOW YOU GET ON..
Old Jan 10, 2006 | 06:43 AM
originalcabbie
cheers for the help. it turned out to be rotor arm and dizzy cap! Fooking fords are always broken. Thanks for the garages i will give them a try today.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Mc5506
Oct 5, 2015 09:57 PM
Russ Payne
Sep 25, 2015 08:29 PM
