Hello All! Problem with RS Focus.
Old Jul 15, 2004 | 11:45 PM
Tom_RS's Avatar
Tom_RS
Default Hello All! Problem with RS Focus.
Hi Ive never posted on here before but I find these forums extremely useful for info on all things Ford as you lot seem to know so much! (I was taught flattery will get you everywhere! )
I have owned my Focus for 2 months and since Ive owned it, the water pump has leaked resulting in a fix under warrenty and an apparent oxygen sensor failure which is to be fixed soon (which may be linked to my problem) I know my post is ridiculously long winded but I would very much appreciate you lend me your time and help me diagnose whats wrong with the RS.
Got back from a long day of travelling a few hours ago and the Focus seems to be either playing up a bit or what I dont know! I know very little mechanically so was wondering if someone could help me out!
Drove from Poole on the south coast back up home today and everything seemed fine until we got to Northampton. The battery light came on just as we got on the M1 which Ive been told suggests the alternator is broken. In the end my lights were as dim as side lights but the car was running fine and managed to get to my turn off. Then the battery light turned off and my lights got full power again. It kept on flickering on and off all the way back home with the lights dimming and powering up everytime it went on and off. It finally started seriously going mad between three roundabouts about 3 miles distance between all three. First stretch the ABS light came on, battery light turned off, went off, battery on etc but total loss of all lights in near pitch black. Got across 2 roundabout on the final stretch home and then it seriously playing up, still no lights, started chugging and jerking back and forward till the next roundabout (another mile), ABS light on, airbag light on, battery light on, but the engine management light never ever came on the whole time. Managed to chug our way to the roundabout at literally 30mph with hazards (which barely worked) on crawling down the side of the road. Finally cut out (After 3 miles?!) on the roundabout! Managed to roll into a sideroad where the car wouldnt start at all. Left it 5mins and it started?! Somehow got it home but it sounds completely shagged! Really tinny and its backfiring a bit. Then I started it up about 30mins ago and everything is fine with lights working properly and everything?!
Any suggestions as to whats wrong with it?
Old Jul 16, 2004 | 12:34 AM
Azrael's Avatar
Azrael
Hmm sounds really weird. I am no expert on electrics but maybe failed voltage regulator can give such symptoms? Lack of charging form alternator can be e.g. the wires conneted not properly and loosing contact - My Escos had one wire loose on the alterntor and there was no charging on small revs/little electricity use. The warning lights coming on are prbably due to ECU's detecting voltage too low for operation ane shutting down. It's probably still on warranty so make Ford boys some hell.
Old Jul 16, 2004 | 12:36 AM
Fastmaul's Avatar
Fastmaul
K155MYRS
BTT for him
Old Jul 16, 2004 | 01:01 AM
datar18's Avatar
datar18
surely it shouldn't be your problem mate, its pretty much a brand new car and is still under warranty so get on the phone to fords as soon as p and get them to sort it pretty sharpish because you dont wanna be spending loadsa cash on a car that you're not able to drive!!
that just aint on at all!! but what with the engine losing power and everything flashing at ya like mad, gotta be either dodgy connections on the battery or the alternator, everything runs off of these 2 parts and therefore if one fails then the car will shut down to a degree!!
good luck with it all mate and hope it all turns out for the best
Old Jul 16, 2004 | 06:42 AM
danvisteon's Avatar
danvisteon
that is the voltage regulator playing up in the alternator, get it fixed under warrenty, the car will eventually cut out due to low voltage to the ecu, i have asked a guy at work ( he is the warrenty guy for alternators and starters) and he said that this is a rare thing to happen but will be covered under warrenty , just take the car back and get a new alternator fitted
Old Aug 14, 2004 | 07:22 PM
emndean's Avatar
emndean
hiya m8. In the n/s & o/s footwells behind the kick pillar trim, there are focus & focus RS main earthing points bolted in via an 8mm bolt. Check that they are all tight, check fuse box and pull out KAM fuse & replace to reset module memory. Bit of a guess, but that might be your prob mate.
Car not going over 30mph and running lumpy is because it is in Limp mode to protect engine damage. Hope this helps!!
Old Aug 14, 2004 | 08:02 PM
Sticky.'s Avatar
Sticky.
Get the car back to Fords & ask for a courtesy car & tell them to sort it out.
These cars are virtually brand new, so for you to be having all these problems mate, id send it back under warranty, & get your local ford dealer to sort it for you mate.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
