anyone got a pectal loom diagram ?
i have just got a pectal loom which was put togeather by a compony called motorsport wiring (or somthing close to that )
and what im after is a diagram of the relay wiring, the loom is mint but where the plug is for the relay wiring it seems to have been a bit butcher'd. also any diagrams on the antilag would be nice if poss
i will get some pics if need be
Originally Posted by DazC
Yes, as Dave says. Pectel (with 2 'E's and no 'A's) make a loom to your spec.
Motprsport Wiring should be able to provide you with one.
thanks, i was only after a bit of help
for anyone that wants to help heres a picture of the bit i mean
and does anybody know what this switch is for ??
Originally Posted by rsrob
obviously if you had read the post before marking my post with your red pen you may have understood that i already have the loom, and all im after is a diagram because a small bit of the loom needs tidying up.
If it is like a Pectel loom then there will be a serial number on it. Give Motorsport Wiring this number and they should be able to give you a diagram.
[quote
/rsmania/dans006.jpg[/img]
155lee
Oct 24, 2015 11:11 AM
muz
Sep 30, 2015 08:29 AM
Fudgey
Sep 17, 2015 01:06 PM
