CPS reading old spanners but not flywheel
Old Dec 4, 2005 | 03:40 PM
Lee-j's Avatar
Lee-j
Default CPS reading old spanners but not flywheel
Had another bash at the xr2i today, took reading on multimeter CPS shows a good reading when waved in front of old spanners and metal stuff but when bolted back in and engine turned over, nothing! Could a dirty flywheel be a problem? took the starter motor off to have a look and flywheel was a bit greasy, nothing major though
Old Dec 4, 2005 | 03:53 PM
HORNETS7's Avatar
HORNETS7
no its nowt to do with a greasey flywheel !
have u had this car running before?
Old Dec 4, 2005 | 05:47 PM
Lee-j's Avatar
Lee-j
Not personally, but it was running, then it just stopped. So it was towed to the garage, eventually given to me and now I want it running! apparently it just died one day and was brought in, I've tried loads of things and narrowed it down to not getting a reading from the flywheel as stated before, although the CPS does read from other things when not mounted on the block
Old Dec 4, 2005 | 05:50 PM
HORNETS7's Avatar
HORNETS7
has the 2i got a cut off switch in the passenger side footwell behind the plastic cover?
so its just died noones changed the flywheel ? and put a non efi one in have they?
Old Dec 4, 2005 | 05:52 PM
grease monkey's Avatar
grease monkey
the air gap between the flywheel and the sensor mite be 2 big you should check that there is no lateral play in the crankshaft because the thrust washers could be worn .
Old Dec 4, 2005 | 06:03 PM
Moonie's Avatar
Moonie
Check the sensor is seating correctly in the bush and also the bush is correctly mounted in the block. If either are out the air gap could be too large.
Old Dec 4, 2005 | 06:04 PM
Moonie's Avatar
Moonie
Also check the bell housing bolts are tight. If not it can corrupt the signal from the cps and the ecu will not be able to dectect engine position/speed.
Old Dec 4, 2005 | 06:09 PM
Lee-j's Avatar
Lee-j
Good suggestions, thanks. Have checked the bolts they are ok, no work has been done on the car it just stopped one day. Air gap sounds likely, the CPS is known to be good, it has been tested on a multimeter and works fine but doesn't read AT ALL when the multimeter is connected to it and its bolted to the block. I know the ECU needs the correct signal to work properly but my CPS isn't giving out any signal at all let alone the wrong one
Would thrust washers wear enough to alter the gap so it wouldn't read at all?
Old Dec 4, 2005 | 09:20 PM
davidreader5's Avatar
davidreader5
HI,
IF you put a meter straight to the cps with the loom plug off, is there
any signal, if yes, have you checked the loom connector plug for the
cps for any breaks to and from the sensor ECU,eg, good continuity,
from memory i dont think the efi xr2 has a adjustable air gap,
DAVE R.
Old Dec 5, 2005 | 12:31 AM
SafeChav's Avatar
SafeChav
hello again mate
CHRIST i cant believe you're still battling this one that was AGES ago you posted about it
I'd be a bit like this little fella by now if i were you
do you remember i said to you about the posibility of the flywheel bolts being loose and allowing the flywheel to move far enough away to not give a reading
Looking a bit like that could be the case....? Either that or as grease monkey said, the thrust bearings could be worn although i'd expect the engine to be making all kinds of funky noises if this was the case....
Looks like the only way forward for you my friend is to whip the gearbox off Definately NOT a fun job.
You now know the CPS sensor is good, and also isnt producing a signal when fitted to the car, so this is the next job as long as you are satisfied its mounted satisfactorily?
You should be able to lower the engine and swing the box round far enough to find the problem with out having to pop the driveshafts out, so its not all bad news....
Old Dec 5, 2005 | 05:45 PM
grease monkey
ive seen this happen on a focus it ran sometimes then it would just cut out and not start for a while ended up the thrust washers were fucked .
you should if there is any play on the pulley on the timing belt side first before you pull the box out .
if i were you i would see if you could get your hands on a different cps or even try yours in another car it would probably be the same as any efi cvh out of an escort or orion or fiesta.
did you check the continuity of the wires back to the ecu ?
Old Dec 5, 2005 | 08:08 PM
Lee-j's Avatar
Lee-j
Thanks again everyone, I managed to get the car moved onto the tarmac at the garage so next time I go over I will push it inside where i will have the luxury of 4 post lifts and lamps
This will allow me to check the pulley for movement and also if need be whip the box out for a closer look. Up on a ramp with proper lighting and air tools has gotta be better than laying on the ground at dusk outside!
You know it! I've sold my other car now too so kinda would like to get this one on the road so I dont have to go everywhere in the works van!
Old Dec 7, 2005 | 09:31 AM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
have you checked TPS and coilpack??????
Matt
Old Dec 9, 2005 | 10:11 AM
SafeChav's Avatar
SafeChav
4 Poster ramp?
Air Tools?
RESULT, let us know how you get on.
Matt Lewis: I think he has checked that, seems like a bitch of a problem this one
Old Dec 24, 2005 | 01:41 AM
SafeChav's Avatar
SafeChav
U fixed it yet mate?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
Iain Mac
Sep 30, 2015 09:39 PM
