4x4 cossie help
Old Nov 26, 2005 | 05:06 PM
FingerZ!'s Avatar
FingerZ!
Default 4x4 cossie help
does anyone have a cossie crank pulley puller tool as i am having difficulty removing the pulley wheel off my crank shaft. Local to romford essex
failing that, does anyone have a link to what one looks like or maybe a link to somewhere i can buy one online as i need it this week and might need it again anyways
i have already managed to destroy my crank position sender in the process, and might have cracked my radiator along the way too - extremely pissed off as it was a new rad lol!
oh well the joys of cosworth repair!!!
cheers
timbo
P.S - im tight at the moment due to bank problems so the cheaper the better for sensor and puller - any help appreciated tho!
Old Nov 26, 2005 | 05:10 PM
july1's Avatar
july1
All you need is this or something on the same principle:
Hope this help..
Old Nov 27, 2005 | 09:20 AM
FingerZ!'s Avatar
FingerZ!
ah so the 3 holes in the pulley are threaded i take it
Old Nov 27, 2005 | 10:11 AM
FingerZ!'s Avatar
FingerZ!
also i have been told its common for cossie engines to have some water wheeping out of the front corner by th eexhaust manifold on the head - is this right?
thinking that when i refit the head, sticking a bit of well seal on it to prevent this happening agia - i know if its skimmed etc it shouldnt happen again when torqued down properly, but i dont wanna have ot do the job again!
Old Nov 27, 2005 | 12:46 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
If you seal it, chances are you will have to do the job again sooner than if you did it properly in the first place
Good luck with the pulley, while you are waiting for a puller, etc... put loads of WD40 or similar on there to help it ease out.
Old Nov 27, 2005 | 03:17 PM
GAZ345's Avatar
GAZ345
you need something like this
Old Nov 27, 2005 | 09:09 PM
FingerZ!'s Avatar
FingerZ!
managed to get meself a puller but was too big so modified it to suit - sorted the problem altho before i got teh puller i destroyed my pulley wheel and my CPS
leasson learned!
managed to get my self another pulley wheel for about £40 ish which werent tooo bad
need to get cps ready for running tomorrow
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
