Compomotive MO's - Clio 172 Cup
Righto prob a bit of a strange question on a Ford forum but herego's
Mate of mine has just bought a set of 5-spoke Mo's for his Clio 172 Cup off e-bay, unfortunately they don't fit!
He's just found out that the offset isn't right, his car runs 42mm and the wheels are 35mm, he's been told that he can get spacers to solve the problem, is that right? Or is he better off selling them on?
The wheel details are as follows:-
Size: 17" and 8J (width)
Tyres: 205 40 17
Offset: 35 ET
Problem: The wheel will not go over the centre cap of the hub, thinking that
will need spacers to adapt the offset difference
Any help is much appreciated
Tyres: 205 40 17
Offset: 35 ET
Thanks fellas, Im not at all technical but neither are the guys that gave him the advice so thought I'd check
Having material removed from the wheels sounds extreme to a simpleton like me, is that something you would recommend or should he just get rid in your opinion?
Get rid!
Yeah that def sounds like the best idea, cheers to you both for your quick replies, an expensive lesson learnt
if i am understanding you correctly then the centre bore (called pilot diameter in this pic) is too small yes?
![](http://www.volvoadventures.com/wheels/wheel_offset.gif)
if so as mike says get rid. you can get them on but will be a lot fo grief for wheels you can just get in the correct fitment
The wheels were only tried on quickly but yes that def sounds right, Ive forwarded him your diagram and he's going to put the wheels back on ebay tonight. Thanks for the clear explanation
Fudgey
17-09-2015 01:06 PM
