MT75 gearbox whine
Old Oct 11, 2005 | 07:51 AM
Dave Henshall's Avatar
Dave Henshall
Default MT75 gearbox whine
my escos box was rebilt about 4K ago (it was very tight when they had done it and it dragged a lot - it would move the car forwards even with the car out of gear when the engine started ) in the last 1K its developed a slight whine that can be heard from inside the car at first just thought the gearstick, this has now developed to quite a loud whine and can be heard outside louder than in the car.
its obvious it s box out job, but are there any common rebuild slipups that may have occured? its got the proper Mt75 oil in (castrol FMT) and there is no grining or banging, teh gearchance is lovely and smooth, its just this high pitched whine which gets louder and more intense as the car goes faster, it remains even when the clutch is pressed in when coastng at speed.
Old Oct 13, 2005 | 09:41 AM
Dave Henshall
bttt,
anyone?
Old Oct 13, 2005 | 09:58 AM
DazC's Avatar
DazC
Does it do it in all gears?
Old Oct 13, 2005 | 12:54 PM
Dave Henshall
yep, even in neutral, its road speed related, not engine speed
Old Oct 13, 2005 | 12:57 PM
Dave Henshall
gonna try it on ramp with all 4 whells off the ground and get undernearth see if i can find if its the gearbox, transfer box or front diff that is making the noise..
Old Oct 13, 2005 | 02:40 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
I had a similar noise problem with my saff it turned out to be front diff. the bearings were on the way out and the front shaft seals started to weap oil which is the first sign of movement in the diff bearings.
Old Oct 13, 2005 | 05:01 PM
ian rst's Avatar
ian rst
Mine makes a noise but only on neutral with my foot off the pedal, i was told its the transfer box??????
Old Oct 13, 2005 | 06:10 PM
Dave Henshall
how much backlash should the be in teh fornt diff ? mine can turn i'd say about 3/4" before any moevment to the fornt wheels is evident..
Old Oct 13, 2005 | 08:06 PM
DazC's Avatar
DazC
Dave, that is back lash in the whole front wheel drive system. There will be play in the CV joints and hub to CV joint splines etc etc.
Get it up off all 4 wheels and get it driven off the floor and make sure it's not the prop centre bearing or something daft.
Do you know about the long screw driver to the ear method? If not, touch the blade of a screw driver to the suspect noisy part and then stick your ear on the screw driver handle.
Old Oct 14, 2005 | 07:53 AM
Dave Henshall
oh yes, good old 'dr. possidrive'
might even try dropping the props off and see if that points me to the box itself.
Old Oct 14, 2005 | 01:08 PM
DazC's Avatar
DazC
Worth a try!
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
A.t.p
Sep 29, 2015 05:04 PM
