Smoking Cosworth
Old Oct 7, 2005 | 06:01 PM
Cossy Chris's Avatar
Cossy Chris
Default Smoking Cosworth
Ive got a cosworth which I need a little bit of advice with. When I put my foot down just about when the turbo comes in there is constant smoke that blows out the back of it (blue/black colour). On start up there nothing but there always seems to be a lot of carbon in the back box. Does it need a rebuild or turbo? Its running standard boost.
Any help would be great, Thanks
Old Oct 7, 2005 | 09:11 PM
Dave McB's Avatar
Dave McB
blue= turbo
black=overfuelling.
Firstly, take the hose from the turbo to the intercooler off. if this is oily, the first port of call is the turbo needin replaced. if its not, then its rebuild time buddy
Old Oct 9, 2005 | 11:04 AM
Cossy Chris
Theres a little bit of oil in the turbo pipe but nothing to bad really. How much are you looking at for a rebuild roughly?
Old Oct 9, 2005 | 06:29 PM
mk2rstaff's Avatar
mk2rstaff
if you cant do it urself about 1500 too 2 grand mate
Old Oct 10, 2005 | 03:46 PM
Cossy Chris
What if I can do it myself? How much then?
Old Oct 10, 2005 | 04:06 PM
mk2rstaff's Avatar
mk2rstaff
one of my mates just done his 3dr for 380 all in but he did all the spanner work himself, with some help
Old Oct 10, 2005 | 09:36 PM
cul's Avatar
cul
it could still be your turbo...
there are oil seals on both sides of the compressor and if the seal on the exhaust side is gone then it will leak straight into the exhaust and blow smoke.
This is happening in my erst at the mo and the car is after a full rebuild..
best bet is to remove the eshaust at the turbo and check to see if there is any oil in there on the turbo around the fins on the compressor.
hope this helps...
Old Oct 13, 2005 | 05:03 PM
ian rst's Avatar
ian rst
Mine does that i thought it was un burnt fuel as you boot it. There is no oil in my pipe either.
rsturbo27
Sep 1, 2015 09:54 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
The Enigma
13
Aug 20, 2015 09:38 PM
Aug 14, 2015 07:29 AM
Adam-M
22
Aug 10, 2015 10:46 AM
