COSSIE engine help/advice please!!!
Old Sep 30, 2005 | 12:50 PM
RScrew69's Avatar
RScrew69
Default COSSIE engine help/advice please!!!
right mate has had some issues with his cossies engine smoking abit and missfiring. Also the 2 middle plugs no 2 and 3 and are filling up with black soot and 1 and 2 seem fine.
He had a compression test done on the engine and it read
140/130/120/140
The engine was recently rebuilt about 10k approx its a 200 block had .5 oversized pistons etc fitted and new oil pump new bearing, crank ground etc.
Would it be possible to just change the rings on the pistons all the way across? would this remedy it? Why else could the compression be low ?
Whats should the compression ratio be for a healthy 200 blocked cossie engine?
cheers in advance guys
Old Sep 30, 2005 | 01:26 PM
ellicoss's Avatar
ellicoss
What colour is the smoke as it sound more like its over fueling tell him to swap the outside injectors with the inside and see if 1 and 4 do the same cheers james
Old Sep 30, 2005 | 01:29 PM
RScrew69's Avatar
RScrew69
ok will do that. Its smoking blue and gets thinner and clears up as it get to running temperature. But as said 2 middle plugs are black soot and even when cleaned get black soot over them and the 2 outer ones are fine and good an healthy
Old Sep 30, 2005 | 01:43 PM
ellicoss's Avatar
ellicoss
If it smoking blue its burning oil so might well be rings then .Does th car use alot of oil as if its that bad sounds like it will cheers james
Old Sep 30, 2005 | 06:29 PM
boost mad's Avatar
boost mad
could be valve stem oil seals
Oct 9, 2015 07:38 PM
Gadget
Aug 26, 2015 01:02 AM
kosienutter
31
Aug 22, 2015 09:55 AM
MARKYMARKONE
Aug 2, 2015 09:33 PM
lockie
Jul 31, 2015 10:03 PM
