s2 boost problem please help
Old Nov 22, 2003 | 07:26 PM
Default s2 boost problem please help
i have rebuilt a series 2 erst done about 3000 miles since. now when i try to accelerate the boost drops to 5psi on the gauge but it seems like the brakes have been slammed on. and it splutters. if u r on a hill it is worse. it has stage 1 chip stage 1 hybrid collins-31actuator 4"magnex k&n running 16psi (was anyway) any help would be greatfully appreciated. is it possible it is the ammel valve or metering unit?
Old Nov 23, 2003 | 04:28 PM
Stu @ M Developments's Avatar
PassionFords Creator
Im afraid this could be a LOT of things mate...
Start with looking for air leaks, especially dump valves.
Then investigate the amal valve connection is fine.
Old Nov 23, 2003 | 09:25 PM
EIL132's Avatar
EIL132
Also check the intake hose as it may be collapsing.
Old Nov 23, 2003 | 09:33 PM
Default cheers lads
cheers for the ideas i have sprayed everywhere today with easy start with no signs of leakage i will keep on looking. thanks again
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
