help needed asap
Old Sep 17, 2005 | 03:56 PM
cossiegreg1's Avatar
cossiegreg1
Default help needed asap
iv just went to change the phase sensor on my saff cos and the old one was that fucked one of the wires had corroded away,iv just replaced it with a brand new one and when i fired the car up it idles at over 2000,after i rev it it drops to 1000rpm then goes back up to 2000rpm.
Old Sep 17, 2005 | 07:07 PM
Alvyn's Avatar
Alvyn
did u gap it also?
Old Sep 19, 2005 | 03:50 PM
cossiegreg1
Originally Posted by Alvyn
did u gap it also?
how do i do that? i fitted it thinking it would b just a straight swap.pls help im sick as fk
Old Sep 20, 2005 | 04:07 PM
cossiegreg1
any one help??
Old Sep 20, 2005 | 05:51 PM
Jamie200's Avatar
Jamie200
It's like setting points.
Look at the shaft and you'll see 2 lugs on it, turn engine over until one of the lugs is in line with the phase sensor pick-up. the gap should be between 0.2 - 0.3 mm. If you can use plastic feelers as the sensor uses magnetism and metal blades may effect it (I have used them though).
If this doesn't cure it check you've got the wiring plug the right way round, although they usually don't start the wrong way round.
Old Sep 20, 2005 | 06:02 PM
Chris Honeywell's Avatar
Chris Honeywell
As above m8 and some feeler guage sets have a couple of brass feelers just for this sort of job
Old Sep 20, 2005 | 06:58 PM
Alvyn's Avatar
Alvyn
did u gap it also?
as above sorry haven't been on since you posted 1st time
Old Sep 22, 2005 | 04:05 PM
cossiegreg1
i have gapped it and still idling @2000rpm...i had the car set up about three months ago so the phase sensor must ov been knackerd then,is it possible he may of adjusted the car to suit the fucked sensor??also the car sounds a bit like it missing as if its only firing on three???help please
Old Sep 22, 2005 | 04:20 PM
Dave Henshall's Avatar
Dave Henshall
if it starts runs fine then after a few secons revs up to about 2K it could very well be the TPS out of ajustment, it shuold be in the middle of the elongated holes , and at the ecu with ignition on you should get 0.25 to 0.3 volts dc (assuming its a 4x4 PF09 sensor)
Old Sep 22, 2005 | 04:52 PM
cossiegreg1
i gapped it to 0.4 and it runs how it used to ,but iv still got the problem of when iv drove for about 10min it cuts out and is a twat to start it takes ages to fire back up???
Old Sep 22, 2005 | 04:55 PM
Dave Henshall
does the fuel pump run when it wont start, and is there a spark (have u checked) when it wont start, could be tdc sensor failing or ignition amp after it get warm,
Old Sep 22, 2005 | 05:08 PM
cossiegreg1
thanx for the quick replys.(im running in and out of house!!!)the pump runs when it wont start,i have not checked if it isnt sparking but nxt time it cuts out i will,whats a tdc sensor and where is it ?
JoeyBoyden
Jan 4, 2024 02:36 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
