huming from s2 rearend
Old Sep 10, 2005 | 01:22 PM
robturbo16psi's Avatar
robturbo16psi
Default huming from s2 rearend
hi on the way back from holiday yesterday my rs started to hum from the rear .it can only beheard from 35-40 mph upwards. i've noticed the rear brakes are as hot as the front wheels when i took a slow drive down the shops earlyer.could this be wheel bearings as i needed new wheel bearings for the mot in april as they had movement.could the garage just bodged them to pass? as my rs has only done 2500miles since then.or do wheel bearings ware more if the car is lowerd -60mm on 17" wheels
many thanks
Old Sep 10, 2005 | 02:16 PM
antony215's Avatar
antony215
Escort Rs Turbo
Could be wheel bearing's take them out and pack them with grease see if that stops it if not it could be where you got it to low
Old Sep 10, 2005 | 02:19 PM
robturbo16psi
is it a easy job to do on the drive (no special tools needed )
thanx for your help antony215
Old Sep 10, 2005 | 02:31 PM
antony215's Avatar
antony215
Escort Rs Turbo
Not that hard a job if your handy with the spanners no special tool needed. take the hub off and you will see the cap that covers the bearing theres a big nut you need to undo i think it's a 23mm not 100% sure and then you will see the bearing take it out and pack the hole with grease and smear some round the bearing then put it all back together and see if that works if not it's probley where it' to low. DONT GET ANY GREASE ON THE BRAKE SHOES
Old Sep 12, 2005 | 05:14 PM
monkey24's Avatar
monkey24
wheel bearing do tend to wear faster when you put bigger wheels on due to the extra strain they put on the hubs....or so im told.....packing my hub with grease didnt solve my problem and the bearings looked like new so i changed them anyway and the problem was solved. have you tried putting it on full lock while not moving and checking the clearance between the tyres and wheel arches as it may be rubbing? good luck with the ~MOt~ Lets hope its not an expensive one.
Old Sep 13, 2005 | 04:13 PM
Dean Saff's Avatar
Dean Saff
Sounds like a bearing problem,
Jack the back end up and spin the wheel if the bearing is worn you will feel a vibration through the spring, you can compare each side.
Also dont be tempted into greaseing them as that will do nothing if the bearing is worn the damage is done,
Also if your better of getting somone who knows what there doing to help or do it for you, as the bearing is what holds your wheel on, you dont what to get it wrong as if it fails at high speed you will be in a lot of trouble
Old Sep 13, 2005 | 07:32 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
above,remember to torque all nuts up,your s2 rear hub is 25nm im sure.
Old Sep 13, 2005 | 11:01 PM
GrimmeRS2K's Avatar
GrimmeRS2K
i had this when i changed to turbo rims, got a humming noise at 30 to 40 mph, was like it for a week then i had a rear tyre replaced and it went!, could of been the tyre?
Old Sep 14, 2005 | 05:58 PM
Dean Saff's Avatar
Dean Saff
Very true deformed tyres can cause this noise, but jacking and spinning while spot this.
OrionHayden
Feb 5, 2012 02:08 AM
mikedaf2
Mar 14, 2009 11:20 AM
Spammage
Jun 27, 2008 08:40 PM
GaryHurn
Jun 27, 2005 03:06 PM
