FITTING FIESTA RST OFAB LOOM IN MY S2 RSTURBO????
PLEASE HELP...... I WANT TO UPGRADE MY CRAPPY ESCORT MANAGEMENT FOR FRST OFAB MANAGEMENT. I CANT AFFORD OR FEEL THE NEED FOR COSSIE MANAGEMENT AND HAVE MY HEART SET ON THE FEZ MANAGEMENT(PLUS I HAVE THE FEZZIE BITS ALREADY)iVE BEEN TOLD OFAB IS BETTER FOR LIVEMAPPIN AND ALLOWS A 3BAR MAP SENSOR TO BE FITTED FOR BIG BOOST.IVE DONE LOADS OF ESCORT TURBO CONVERSIONS AND ENGINE SWAPS IN THE PAST BUT I SWAP COMPLETE LOOMS SO THAT ITS A PROPER JOB.THIS WILL NEED CUTTING INTO MY EXSISTING LOOM(SOMETHING IVE NEVER DONE AND DONT KNOW WHERE TO START SEVERAL COMPANYS HAVE SAID ITS EASY BUT WANT TO DO IT.I PREFER TO DO THE WORK MYSELF.I KNOW IT CANT BE HARD AS ITS JUST A MULTI PLUG WITH 5 OR 6 WIRES!!!!!IF SOMEONE COULD TELL ME WHAT WIRE DOES WHAT AND WHAT GOS WHERE I WILL BE ABLE TO SLEEP BETTER AT NITE!!!! PLEASE HELP
im currently researching EFI conversions, got every part to do it, i just need to get a FRST haynes manual so i can get the wiring diagram. Thatswhat i suggest you do, if you can make head or tail them that is theyre not the easiest things in the world to understand. Or maybe the cruise blackpool site, has some wiring connections listed, not sure if its got what you are after?
