Missfire i think?
Old Sep 8, 2005 | 11:58 AM
Twellsie's Avatar
Twellsie
Default Missfire i think?
Has anybody come across this problem?
whilst drivin in 2nd or 3rd as i hit 4.5k ocasionally there is what i think is a missfire, this hardly ever happens apart from when you wanna kick the arse of a scooby or generally on cooler days, but you can trake it back down to 2nd and launch it as hard as you like and it will be fine.
Old Sep 8, 2005 | 12:34 PM
Dave Henshall's Avatar
Dave Henshall
plug gaps, get them gapped down to about 0.6 mm
Old Sep 13, 2005 | 11:33 AM
Twellsie's Avatar
Twellsie
right i have tried that, and the problem is still there
Old Sep 13, 2005 | 12:22 PM
Dave Henshall
could be the plugs failing anyway, fit some new ones, motorcraft 071c's about 12 quid a set from msd
Old Sep 13, 2005 | 01:48 PM
mart.rs's Avatar
mart.rs
sounds like the prob i had with my old s2,it kept blowing out the spark on the plug cos the gap was too large! then found out two of the plugs were fooked,so went and got some new ones( N.G.Ks BCR8ESs) and that cured it fine! that was three years ago,now ive bin told to use cossie plugs( platinum tip style)!
Old Sep 13, 2005 | 03:00 PM
Dave Henshall
i think it is aronic, that rs turbos are using cossie plugs with good results and the cossies are using rs turbo plugs with good results,
Old Sep 13, 2005 | 03:37 PM
mart.rs's Avatar
mart.rs
i think it is aronic, that rs turbos are using cossie plugs with good results and the cossies are using rs turbo plugs with good results, [/quote]
cossies using RST plugs?
Old Sep 13, 2005 | 03:38 PM
Dave Henshall
yep, the 071C's that im using as are many other are rst plugs
Old Sep 13, 2005 | 03:43 PM
mart.rs's Avatar
mart.rs
so what do recommend for a s2 200bhp or more to use?
Old Sep 13, 2005 | 04:16 PM
Dean Saff's Avatar
Dean Saff
About 10 to the gallon...
Old Sep 13, 2005 | 07:08 PM
danxr2i's Avatar
danxr2i
I have the same problem on my 2i and i have'nt managed to solve it.
fish6634
Ford KA
Aug 2, 2015 01:02 PM
ginger1979
Jul 31, 2015 09:56 PM
Ginge !
23
May 28, 2005 01:06 PM
FletchCossie
Jul 19, 2004 08:17 PM
AlexD
Feb 26, 2004 08:59 AM
