congratulations to me and my project !!!
just finding my feet
ok vain i know but fook it
i got commisioned to fit a engine into a car for a customer and there was a twist to it
it was to fit a mfi erst engine to a efi fiesta turbo, he needed it doing quick too and so i had to source the vital efi bit and the 1.8 pully and its all done
thats where it got tricky, he was on a budget and wanted it doing the cheepest way poss
as im a person who likes a challenge i accepted it ( mad aint i )
anyway i got a 60k mile standard erst engine thats never been ragged and never been even chipped ( the car it came out of never had a alarm or a imobiliser )
so heres where i started , i removed the fly wheel and with a some advice and help by christian ( christian and beccy) i decided to see if the block could be drilled
it looked easy so the next step was to get a template, this it actually the chickey box my thinking food was in when i was deciding how to make a template out or metal, plastic ect , talk about think too much
then when i center punched the block ( and broke me center punch ) i managed to get this far
then i blut the bit so had to order a new one , never gonna drill ablock cheap for anyone else ever again
anyway with that done i had to sort the injector problem out
this was the really really scarey bit and i know im gonna get shot down for this saying ive fooked a head and the car wont work ect, need a pro and the redbull mechanics to do such a complex job
bollox, i got the dremel out and ground out the holes for the injectors , yes thats right i just ground out holes in a engien that i didnt own , but when i checked it against the location it was spot on , looked well done and also i got rid of tie bur marks too ( btw i plugged the holes, im not a total idiot )
so with all my "pro" modding done i set to work fitting the engine
now the camera i left at home the next day so no piccys so ill just say waht happened
when all was plumbed in i was worried about the cps and the car not starting or having a missfire due to me drilling the hole wrong of square shaped
but with the assitance of urban legend we decided to start the car and listen for missfires
pressed te remote start,,,,,,,,,,,,,,,,,,,,,,
car started first time
but was revving at 3500k on idle , we looked at it and kam explaimed the dipstick wasnt in adn so put that back in, i squeezed a few pipes and taped the rocker cover with a screw driver to see if that helped ( incase my no3 philips was also a magic wand paul daniels style )
we restarted the car, revs to 4500k again
ok we looked at all the niuts and bolts we touched and noticed i never put the 2 inside inlet manifold studs on , yeah i know school boy
lam decided to make fun of me and call me a idiot and said why my cossie is soo fucked ect due to me working on it
we then start the car again , at that time we discovered the car has no missfire at all !!!!!!!!!!, its not missfiring so the cps is done spot on
how did i know ya might be asking
its cause the cars now reving its pants off adn banging the rev limiter on idle , i call the customer and tell him the good news about the cps
anyway we look into it and then remove the inlet after some good advice from brom@zoo ( cheers for taking the time to help me )
i noticed that there was a air leak caused by the efo inlet gasket leaving a tiny gap in all 4 cylinders and that could be causing the air leak
i spoke to simon@SECS who adviced me to try a leakdown test if i had compressor and find out for sure if theres a leak , problem is i dont have a compressor , dont worry though as i had a another idea
get the missus hairdryer and clamp that to the crossover and see it theres any HOT air comming out of the inlet gaps , i sht you not, i made my own leakdown test kit from argos
its fooking worked too, i wa right it was leaking
i had to rethink a idea how to repair this problem and i managed a secret way to solve it that i will not tell anyone about but it i tried that after a few mods and guess what !!!
the car now starts and done rev its pants off and dont missfire
i made a efi engine froma mfi and it cost em a bit of labour, a hole cutter and a few dremel bits from halfords
i know prob no fooker cares but i very proud of this as it worked
also its a good excuse to say a thankyou to urban legend for allowing me to use his garage to convert the car
and to cowboi for taking out all the nuts and bolts i rounded off as your the tits at that
i should have took loads of pics but i just wanted the car working so im sorry
im gonna get a few of it all done and after its setup to show that a idiot like me can make a car work
might i also add that this i have only ever been shown how to remove a engine once by fletchcossie and the rest os all by advice i got over the years from rsoc and passionford members
now imo thats real diy, just dont try it at home kids
oh and wait for the next one, thats gonna make ya think a bit
gonna take load of piccys of that one though
hey toom em ages and its genuine DIY with so input from fellow passionford users ( though i must state i never told em about my head bodging
i well impressed , only cause it works though , i really thought it wouldnt
it runs a dream !!!!!, i even managed to sort the water temp and where gonna wire up the other gauges to avoid anymore melt downs on the way to car shows
he melted 2 pistons not one
by the time we got back from santa pod there was soooo much coffee goo coming out of the breather the engine bay was cream
FPMSL well done m8 Im tring to work out whot you used to stop the air leak tho But cant think of any HOUSE HOLD products that would do the jod yet
I know was it a home made gasket made out of a CORNFLAKE box From your breakfast
Or 2 Gaskets and a metal plate in the middle with the holes cut to the right size in it
My m8s old mad put the efi xr3i engine in his sons xr2 and had air leak on that so he did the above Worked aswell the car FLOW ater that (it had only done 6k on the efi engine for the rebuild) Mined you did sound like it had a turbo on ot @ times strange wisling noise
Originally Posted by big_wig_074
get some cobalt drill bits next time ginge!!! they wont blunt so quick!
i think i used too much presure and blunt it though
i did actually use a frosties box as part of my design , thats not a gasket though, theres bodging and there going too far
btw just had a text and hes driven to work with it
the thing i used to bodge it i jsut realised i never needed to make sure another leak was sorted , as the head dont have the breathing ports there
ahhh well, its done now and its spot on
just need the r/r results after i do a few more mods
cheers for the kind words, if it fooks up dont expect me to post about it but recomend using a efi addaptor plate
mate i never took the engine out by hanging the block on shoe laces
and it works !!!!!, everyone i knew said it would, i was the only one saying ive got the spare parts on order and a efi head if we really need to sort it
so far we BODGED a 4x4 cossie turbo on it, the engine in it, dal bodged a cossie cooler on it, its got a mk3 dash in the xr2 that dalk bodged in it
the only xr2 part of the car is the shell
its even had cossie brakes bodged onto it
but it works, its when ya bodge struff and it dont work ya worry
think of all the cars using calibra turbo pistons !!!!, thats a bodges but works
im just happy is does work though, i am the man
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
