Quaife or not?
Old Nov 18, 2003 | 04:00 PM
cossymad's Avatar
cossymad
Default Quaife or not?
Got a box 4x4 esc cossy supposedly a ''QUAIFE'' . I can't fit a std clutch cable as it won't fit through the hole in the housing. I have been told this is because the Quaife housings were slightly too small and you must drill them out. Anyone heard of this? The under neath of the rear half has a ford oval cast in it. Could it be quaife internals and bell housing with ford rear casing? or am I just being optimistic?
Old Nov 19, 2003 | 09:43 AM
cossymad's Avatar
cossymad
Anyone?
Old Nov 19, 2003 | 10:20 AM
DazC's Avatar
DazC
What quaife?
If it's a big tooth box then they use the Ford casing which should fit. The one fitted to my Dads car was a Ford casing but with a big tooth gear kit. If you take out the reverse lamp switch you can see the gears. If you have the standard box then you could compare them to see if you have been sold a quaife box. The difference is obvious when you look at the 2 different types of gears.
If it is a quaife box then I see no problem in enlarginf the hole with a drill for the clutch cable.
Old Nov 19, 2003 | 12:04 PM
cossymad's Avatar
cossymad
Cheers I'll look through that switch hole. I have another box but is already in one car, and the 'quaife' one is already in my other one!!
Old Nov 19, 2003 | 03:18 PM
Mike Gurney's Avatar
Mike Gurney
give berni a shout at www.gearboxman.co.uk
he posts on here too
Old Nov 20, 2003 | 08:22 AM
cossymad's Avatar
cossymad
I'll ring him . Cheers.
Old Nov 20, 2003 | 12:51 PM
gearboxman's Avatar
gearboxman
As Daz says, the front case is standard Ford, whether it has a Quaife big tooth kit or not.
Old Nov 20, 2003 | 01:52 PM
cossymad's Avatar
cossymad
Guess I'll have to get my arse into gear and get the thing running and I'll soon know. Cheers.
TPM961
Jan 15, 2018 10:50 AM
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
mark r
Sep 29, 2015 07:27 PM
`spotty
Sep 25, 2015 11:41 PM
cbminis
Sep 7, 2015 09:42 AM
