cosworth running problems
Old Aug 2, 2005 | 11:36 PM
cosworthcapri's Avatar
cosworthcapri
Default cosworth running problems
Iv eventually managed to get my cosworth turbo engined capri running after countless problems,but now its running,the plugs get wet and it starts miss fireing badly,sounds like its running on 2 cylinders.After removing the plugs the tops of the pistons are also wet.The engine recently had a rebore and new rings,so not that. someone suggested overfuelling? any ideas?
Old Aug 3, 2005 | 12:23 AM
jon@work's Avatar
jon@work
1) Ensure ignition is OFF.
2) Remove rear of ecu plug cover and insert plug back into ecu.
3) Turn ignition back on (do not start engine)
4) COOLANT TEMP SENSOR: Check resistance pins 29 and 11 for 800 ohms to 5000 ohms (depends on temp). If out of range, inspect wiring or replace sensor.
Old Aug 4, 2005 | 12:09 AM
cosworthcapri
Cheers mate,il give that a try tomorrow.
manuel boeckx
13
Oct 3, 2015 02:29 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
