help please - UPDATED!!! MORE HELP NEEDED ASAP!!!!!!
Old Nov 12, 2003 | 03:29 PM
adamS2RST's Avatar
adamS2RST
Default help please - UPDATED!!! MORE HELP NEEDED ASAP!!!!!!
Hi, I need to get my calipers off but cant get the top bolt off to undo them, the bolt is close to being rounded and I dont want to have to fook it completely, how else can I get them off? I know there are the alan key holes, but dont have the right size key? For my ERST by the way. Cheers.
Old Nov 12, 2003 | 03:35 PM
Stu @ M Developments's Avatar
PassionFords Creator
<IFRAME marginWidth=0 marginHeight=0 src="http://buy1.snapon.com/catalog/pro_det.asp?P65=yes&tool=all&item_ID=5718&group_ID =588&store=snapon-store&dir=catalog" frameBorder=0 width=800 height=600></IFRAME>
Buy a 7mm allen key
Old Nov 12, 2003 | 03:43 PM
adamS2RST's Avatar
adamS2RST
apmsl! I just might have to Stu.
Old Nov 12, 2003 | 03:46 PM
Thrush's Avatar
Thrush
Irritating c........
Sorry, thread hi-jack
Stu - how do you do that? Get a web page within a post I mean? I see MAD ANDY did it a while back and now you done it? I only get links come up in my posts
Old Nov 12, 2003 | 03:51 PM
TIFF's Avatar
TIFF
Chasing Radders
Splash out on a new allen key you tight git
Old Nov 12, 2003 | 03:57 PM
PJay's Avatar
PJay
Press ctrl and printscreen and then paste it into your paint program then upload it like any other image.
PJay
Old Nov 12, 2003 | 04:02 PM
Toe Knee's Avatar
Toe Knee
Thats how u put up a pic link, hes on about inserting a whole page link from the main source(URL) not by uploading it himself
and yea im interested to know how 2!!!!!!!!!
Old Nov 12, 2003 | 04:04 PM
adamS2RST's Avatar
adamS2RST
Oi Tiff, shut it!
And u two, hijakers!!!!
Old Nov 12, 2003 | 04:07 PM
PJay's Avatar
PJay
Like that, you can only do it if html is enabled which probably isn't!!!
PJay
Old Nov 12, 2003 | 04:08 PM
PJay's Avatar
PJay
But obviously is!!!
Old Nov 12, 2003 | 04:09 PM
adamS2RST's Avatar
adamS2RST
Old Nov 12, 2003 | 04:12 PM
Thrush's Avatar
Thrush
So? WTF do you do? What does the code look like?
HTML Code:
http://passionford.webheberg.com/forum/viewtopic.php?p=307337#307337
Did it work?
Old Nov 12, 2003 | 04:13 PM
Thrush's Avatar
Thrush
Old Nov 12, 2003 | 04:15 PM
Thrush's Avatar
Thrush
HTML Code:
http://www.machinemart.co.uk/
god knows!
Old Nov 12, 2003 | 04:16 PM
Thrush's Avatar
Thrush
PJay's Avatar
PJay
"IFRAME marginWidth=0 marginHeight=0 src="http://buy1.snapon.com/catalog/pro_det.asp?P65=yes&tool=all&item_ID=5718&group_ID =588&store=snapon-store&dir=catalog" frameBorder=0 width=800 height=600></IFRAME"
Like that but you need to put open and close arrows on it.
PJay
Old Nov 12, 2003 | 04:17 PM
PJay's Avatar
PJay
oh and lose the """"'s
PJay
Old Nov 12, 2003 | 04:24 PM
Thrush's Avatar
Thrush
So if I wanted to do this in a post where do I find that shit you posted to put in my post, and what are the open and close arrows? These : < > ???
Old Nov 12, 2003 | 04:31 PM
PJay's Avatar
PJay
You have to write it, or store it in a txt file then cut and paste.
<IFRAME marginWidth=0 marginHeight=0 src="http://passionford.webheberg.com/forum/viewtopic.php?t=21975" frameBorder=0 width=800 height=600></IFRAME>
To get this you need:
With these <,> at the start and end.
PJay
Old Nov 12, 2003 | 04:33 PM
Thrush's Avatar
Thrush
Yeah but what I am saying is Jay - where do I find this code to copy and paste? I can't jsut make it up? I tried rightclicking and going to properties and got nuffin.... So where do I find the code to copy and paste?
Old Nov 12, 2003 | 04:39 PM
PJay's Avatar
PJay
EEErrrrr, in my post.
IFRAME marginWidth=0 marginHeight=0 src="change this to the web address you want to display" frameBorder=0 width=800 height=600></IFRAME
PJay
Old Nov 12, 2003 | 04:52 PM
Thrush's Avatar
Thrush
<IFRAME marginWidth=0 marginHeight=0 src="http://www.machinemart.co.uk/" frameBorder=0 width=800 height=600></IFRAME>
Old Nov 12, 2003 | 04:53 PM
Thrush's Avatar
Thrush
Hurrah!
what I meant was Jay, that whole Iframe magin thing - I never seen it before so I wondered wher you got it from.... I will jsut save it as a text file now so I can copy it when I need it....
Old Nov 12, 2003 | 05:38 PM
PJay's Avatar
PJay
what I meant was PJay, that whole Iframe magin thing - I never seen it before
Its HTML code has been around for ever.
PJay
Old Nov 12, 2003 | 05:41 PM
Thrush's Avatar
Thrush
Oh, I'd never seen nor heard of it, lol....
Old Nov 12, 2003 | 08:02 PM
adamS2RST's Avatar
adamS2RST
Default UPDATED!!! MORE HELP NEEDED ASAP!!!! HELP!!!!!!!
Ok, now back to the original topic, i have managed to get the caliper off! WAHEY!!! Now, putting the pads back in is the prob, lol. U have the thre metal clips that obviosuly push inside the piston bit of the back of the caliper, but i cant get it to go in properly, what am i dong wrong?
Old Nov 12, 2003 | 08:07 PM
Thrush's Avatar
Thrush
Sorry Adam
Old Nov 12, 2003 | 08:10 PM
Neil S's Avatar
Neil S
The pad wont fit the piston, or the caliper wont go over the disc with the new pads in?
Have you pushed the piston back?
Neil.
adamS2RST's Avatar
adamS2RST
No worrys mate! Can u help me, check the above post?
Old Nov 12, 2003 | 08:15 PM
adamS2RST's Avatar
adamS2RST
No the pad wont fit the piston, just seems as tho it wont go in but of course it does cos i just took em out, just cant get em back in. wot do i do put on end in first then push the clip back and slide it in or what?
Old Nov 12, 2003 | 08:20 PM
Neil S's Avatar
Neil S
With the caliper off the bracket, fit the inboard pad to the piston. Should be a peice of piss mate Just clips in
Then stick the outboard pad in the backet and slide the caliper over the disc and outer pad.
Neil.
Old Nov 12, 2003 | 08:47 PM
adamS2RST's Avatar
adamS2RST
Hi mate, yea done all that and now the calliper is back over the disc and ive tightened the bolts back up that hold the calliper to the hub, but my disc seems really loose and I dont know why, there shouldn't be play in it should there, pmsl!
Old Nov 12, 2003 | 08:51 PM
Neil S's Avatar
Neil S
Pump the pedal, and the play will be no more
Neil.
PS you should have someone do this while u make sure that the brakes are coming on before you even THINK about driving the car
Old Nov 12, 2003 | 08:52 PM
adamS2RST's Avatar
adamS2RST
AFPMSL, Yea, im a idiot, but i wouldnt have even put the wheel back on like it is!!! CheeRS mate.
Old Nov 12, 2003 | 09:00 PM
Neil S's Avatar
Neil S
NB mate
Neil.
Old Nov 12, 2003 | 09:38 PM
adamS2RST's Avatar
adamS2RST
Big thanks to Neil S. Top bloke. Helped me out when no other bastid on here would help when I asked! CheeRS mate. Thanks alot. Got it all back together and is fine, and so far so good no squeak. I think God is punishing me tho, I just pulled back inthe garage and there is a 3 inch screw sticking out the side of my tyre, in my mint front goodyear eagle venturas! Fucked and I bet they cant repair it! I need two new back tyres, why could it not go in them! BOLLOX!!
Cheers again Neil!
Old Nov 12, 2003 | 09:52 PM
Lee Reynolds's Avatar
Lee Reynolds
So easy you DUMMY PMSL ;
Old Nov 12, 2003 | 09:56 PM
adamS2RST's Avatar
adamS2RST
pmsl. Yea, I know, but I can only do easy things, and now I have done it I can do it again easy.
Old Nov 12, 2003 | 10:19 PM
Lee Reynolds
first time for everything matey
Kyle Langford
27
Aug 5, 2019 07:54 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
borboyous
Aug 22, 2015 11:17 AM
155lee
Aug 14, 2015 11:21 AM
col93saphcos
Aug 7, 2015 03:21 PM
