FUEL PUMP OR FREAK RST PROB
Old May 28, 2005 | 04:05 PM
kurdt5's Avatar
kurdt5
Default FUEL PUMP OR FREAK RST PROB
ON WEDNESDAY I WAS DRIVING AT 40MPH WHEN THE CAR JUST CUT OUT MID DRIVING JUST DIED, I ROLLED IT TO THE KERB AND IT JUST TURNED OVER WITHOUT WANTING TO GO
THE CALL OUT PEOPLE ASKED ME TO TURN IT OVER WHICH I DID, THEY SAID IT SOUNDED LIKE NO PETROL WAS GETTING THROUGH.
HE RECKONED IT WAS THE FUEL PUMP AND GAVE THE CAR A BOOST FROM A BOOST PACK FROM UNDERNEATH THE CAR WHICH GOT IT GOING.
TODAY IVE GONE OUT AND THE BATTERY IS AS DEAD AS THEY COME. NO DASH LIGHTS NOWT.
AFTER CHARGING IT I DROVE THE CAR AFTER 4 DAYS, I SPEED UP IN 3RD AND IT CUT OUT, I MANAGED TO JUMP IT IN 2ND AND DRIVE TO THE GARAGE.
THEY RECKON IT ISNT THE FUEL PUMP AND CANT EXPLAIN WHAT HAPPEND AS I DROVE HOME 6 MILES WHEN I GOT THE BOOST PACK TO START ME UP. THEN STARTED AND DROVE TO THE GARAGE.
THE MECHANIC SAID IF THE FUEL PUMP WAS GOING I WOULDNT START LET ALONE BE ABLE TO DRIVE IT.
SINCE THEN I HAVE STARTED IT EVERY DAY AND DRIVEN AROUND THE BLOCK BOOSTING IN 3RD NO PROBS AND GETTING INTO 5TH GEAR.
HAD THE ALTERNATOR AND BATTERY CHECKED, AND THE STARTER WAS REWIRED LAST MONTH.
IM STUMMPED, MY TAX IS DUE TUESDAY, SHOULD I SORN IT TILL JUNE AND GET A PUMP AND RELAY AND HAVE THEM DONE.???
OR CARRY ON DRIVING AND PRAY??
Old May 28, 2005 | 04:35 PM
D7AKE's Avatar
D7AKE
Is it a Fiesta rst or an escort rst?
Old May 28, 2005 | 04:37 PM
kurdt5's Avatar
kurdt5
ITS AN ESCORT RST SERIES 2.
Old May 28, 2005 | 04:41 PM
D7AKE's Avatar
D7AKE
mine did this I had aproblem with the metering unit I just swapped it and it was sorted
Old May 29, 2005 | 06:37 PM
kurdt5's Avatar
kurdt5
HAVE GONE OUT TODAY TO RISK IT, GOT SOME PETROL AND HIT THE BYPASS,
I GOT TO 80MPH OVERTAKING WHEN THE ECU CUT IN AND ARCHED THE CAR CUTTING IT OUT, IT WOULDNT JUMP IN ANY GEAR.
AS IT ROLLED TOWARDS STOPPING AT 5MPH THE REVS SHOT FROM 0-2RPM,
I SAT FOR A FEW MINUTES THEN DROVE AROUND THE ROUNDOBOUT WHEN THE CAR CUT AND DID THE EXACT SAME THING BEFORE CUTTING DEAD AT THE LIGHTS.
IT STARTED AFTER 10 MINUTES, I TURNED THE BOOST DOWN TO 10PSI AND DROVE TO MY MUMS AND THEN HOME WITHOUT ANY PROBLEMS.
FUELLING????.......HIGH BOOST????
WILL SPIN IT TOMMOROW AND SEE WHAT IT DOES WITH THE BOOST DOWN, HAVENT HAD ANY PROBS BEFORE.
Old May 29, 2005 | 06:48 PM
Rs1's Avatar
Rs1
Ive had similar probs when the alternator intermittantly stops charging,it more so provocable in high gear high load situations.
A m8 has had a similar prob with his s2 with the alarm cutting the fuel pump every know and then,i suspect that could be a wiring fault somewhere.
Also check the main live down to the starter,make sure it hasnt rubbed through the sheathing and is not earthing out on the block or as it cross the gearbox.
As for overboost you will get full cut if theres too high a pressure and or the inlet temp is too high.
Old May 30, 2005 | 05:14 PM
kurdt5's Avatar
kurdt5
WELL I TOOK THE CAR OUT, RUNNING FINE, WAS QUITE HAPPY WHEN...........CUT OUT.
4 HRS IN THE BURNING SUN......500 YARDS FROM THE FISHING LAKE I WAS HEADING FOR, I WAS UP FOR A GREAT SPOT OF CARPING.
CUSS CAR CAME OUT AND LUCKILY IT WAS A FORMER RS OWNER WHO CAME.
FOUND I HAD NO SPARK, TRIED TO SORT IT FOR AGES ALSO OIL IN THE DISTRIB CAP. WENT TO TOW ME WHEN THE CAR TURNED OVER.
FOLLOWED ME FOR 4 MILES BEFORE SHE CUT OUT AGAIN.
FOUND CORROSION IN THE COIL AS WELL AS NO SPARK, TOWED ME HOME WHERE MY CAR STARTED UP.
SO NEW DISTRIBUTER BODY....£85.....NEW COIL...????
THEN HOPEFULLY SHE WILL BE OK.
STILL STARTS BUT I AINT RISKING IT AGAIN!!!
Old May 31, 2005 | 08:28 AM
turbo.jon's Avatar
turbo.jon
its the pink relay under the drivers dash its for the fuel pump they are very comon in going wrong i had all same problems with mine i just changed it an worked fine
jon
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
gcfcos
88
Sep 15, 2015 03:48 PM
Billy_RS
Sep 13, 2015 04:17 PM
