Problem with Sparking...
Old May 23, 2005 | 05:25 PM
tipper's Avatar
tipper
Default Problem with Sparking...
Hope someone can help. Ive got a ka and im in the process of putting an xr3i engine into it. Been doing the wiring today, but i cant get a spark to work when im trying to crank the engine over. So when the starter is cranking the engine, there is no spark, but as soon as i let off the key so it goes back onto the ignition, it sparks only once.
What is going wrong?
Cheers, Alex
Old May 23, 2005 | 05:58 PM
boost mad's Avatar
boost mad
xr3i engine?????? as in a zetec or a cvh ? mfi or efi
Old May 23, 2005 | 06:18 PM
tipper's Avatar
tipper
dont worry, problem solved.
the problem is the ignition feed to the coil pack. when the key is turned to crank the engine, the voltage drops to 0.
To solve the problem, i selected the 30amp fuse on the top left on the fuse box and spliced into the big fat purple wire.
this wire keeps voltage when the key is turned.
The engine will now run!!!!
Its a CVh EFi engine.
Alex
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
