How important is vechicle speed sensor?
Old May 17, 2005 | 11:27 PM
Azrael's Avatar
Azrael
Default How important is vechicle speed sensor?
I just found out that my vechicle speed sensor was fooked. What kind off influence can that have on engine running? COuld ths be the reason for engine stalling when pressing the clutch?
Old May 18, 2005 | 06:35 AM
radiant red's Avatar
radiant red
Your ecu needs to know how fast and what position the engine is in so it can make correct calculations for the fueling. The speed sensor (crank/cam) relays this info back so yes, they are vital.
Old May 18, 2005 | 08:27 AM
Azrael's Avatar
Azrael
I am talking about VECHICLE SPEED sensor. NOt crankshaft position or camshaft position sensor.
Old May 18, 2005 | 10:36 AM
sailorbob's Avatar
sailorbob
A faulty VSS could cause the stalling, it is used in the ISC strategy calculations.
Old May 18, 2005 | 05:32 PM
Azrael's Avatar
Azrael
Thx. That helps a lot!
Azrael's Avatar
Azrael
Old May 19, 2005 | 07:41 AM
Stu @ M Developments's Avatar
PassionFords Creator
As Bob says, its used to make the idle pause slightly higher for emissions purposes as your cruise to a halt and it drops finally when the vehicle is sationary, unfortunatelt, the EEC cars dont have a strategy that works properly if this sensor goes down, so they tend to stall or idle very poorly.
Old May 19, 2005 | 08:28 AM
Azrael's Avatar
Azrael
Thx Stu. I just managed to find such sensor on the shelf at Ford dealership. Will be fitted before running the car. Now only TCA's and shafts and it will be running.
Old May 20, 2005 | 09:02 AM
sailorbob's Avatar
sailorbob
In addition to what Stu said, the VSS also is used to determine spark strategy at idle (spark is sometimes used to control rpm) in the COSY ecu. How did you find out the VSS wasn't working, did you get error 452? Incidentally are you running a chipped ecu? I know of one tuning company whose 270 chip lets the ecu think there is no VSS present, if youv'e got one of their chips a faulty VSS wouldn't be the cause of your problem.
Old May 20, 2005 | 11:51 AM
Azrael's Avatar
Azrael
It is COSY Ecu
[quote]
[/qote]
No, my VSS was just mechanical broken. I found it by my speedo not working as speedo cable wasn't driven.
I run ECU with superchips module, now switching to chipped ECU by STU@MSD.
Old May 20, 2005 | 12:33 PM
sailorbob's Avatar
sailorbob
You should have got an error code, I believe the ecu looks at engine conditions and decides the vehicle is moving if certain conditions are met, if no VSS signal is received it posts the error code.
I don't know if Stu cancels out the VSS_PRESENT switch in his chips
Old May 20, 2005 | 02:13 PM
Azrael's Avatar
Azrael
I don't know if I got error code or not. No Ford dealership could comunicate with my car's ECU. I will try after changing ECU once more.
Nobody knows anything about those ECUs over here
Old May 20, 2005 | 10:47 PM
k10cos's Avatar
k10cos
would this be the same on a fiesta turbo aswell with ofac efi management? if its not connected, car stalls etc when clutch pressed, i.e when coming to a junction etc?
cheers
Old May 21, 2005 | 05:33 PM
Chris Honeywell's Avatar
Chris Honeywell
My car had one two years ago it broke so i just chucked it
car runs fine is it best if i get a new one and plug it in??
as i'm worried now
Old May 22, 2005 | 05:08 PM
sailorbob's Avatar
sailorbob
k10cos, could be the problem but I don't know too much about OFAC code.
Chris, if you are running 450 bhp I expect you are not running eec mangement and the VSS won't be a problem
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
fordrallycar
Sep 30, 2015 07:57 PM
