Running hot...Any Tips???
Old Jun 14, 2004 | 05:59 PM
CosRush's Avatar
CosRush
Default Running hot...Any Tips???
My Sapph 4x4 engine is running at about 98degrees today, im using the correct ratio of coolant to water plus Water Wetter added.
Any idea's how i can improve the cooling without fitting a new rad?
What about the Thermostat?
I assume once it has reached its temp and is fully open is it restictive by much?
Would there be any benefit in drilling some bypass holes or running without the stat at all?
Any advice...
Old Jun 15, 2004 | 10:14 PM
markcoznottz's Avatar
markcoznottz
whers the needle sittin on the gauge?
Old Jun 16, 2004 | 05:01 AM
CosRush's Avatar
CosRush
exactly 98 degrees. Im using seperate gauges...
Old Jun 16, 2004 | 05:43 AM
darren.cudd's Avatar
darren.cudd
fit a fook big fan and one of these
adjustable from 70 deg to 120deg, set it to 75ish and you should be fine i got a bigger rad than your probably using but mine never goes over 85 with one of these fitted
Old Jun 16, 2004 | 06:21 PM
markcoznottz
no u mupppet on the standard gauge.do the fans cut in?
Old Jun 16, 2004 | 07:32 PM
CosRush's Avatar
CosRush
Read my reply above...
Ive got seperate gauges.... NOT the standard one.
Thats why i know it is 98degrees
My fans cut it at about 75degrees but thats adjustable
Old Jun 16, 2004 | 10:11 PM
markcoznottz
check ur rad wen the engines hot, if the rads cold at the bottom half its fucked time to get it recored.
Old Jun 16, 2004 | 11:49 PM
PGT's Avatar
PGT
cos rush - i think ya car is a dax rush right? well the problem is frontal area and heavy right foot. the rads dax offer for the rush are limited in their ability to dissipate heat from the the engine for the following reasons:
1) small frontal area of radiator (try and find another car with a bhp potential of 350-400 with a tiny rad like the rush!)
2) proximity of the rad to other bits in the engine ie rad is partially covered by chassis rails etc (even worse in mine as its 4wd and the dif is there)
3) poor general airflow through the engine department because there is no where for the air to go from the rad and the i/cooler. dax's scoop thingy is a gimick. duncan cowpers car had large vertical side vents on each side of the car at the rear of the engine bay to help
dax recken that the newer alloy rad is 30% more efficient than the old one. ive got both and not convinced. the new ones are made by dockwray engineering in silverstone.
Old Jun 17, 2004 | 07:25 AM
CosRush's Avatar
CosRush
pgt,
Thanks for the reply.
You're right about the design problems, but i know several others who haven't had cooling issues and there's are 330bhp+ whereas mine is still standard
Ive seen the nice 4 row rad Pace makes, but that means more money.
Have you had any problems with cooling?
How have you plumbed yours?
Old Jun 17, 2004 | 06:32 PM
markcoznottz
apoligies cos rush didnt no u had rush
Old Jun 18, 2004 | 07:40 AM
CosRush's Avatar
CosRush
No problems Mark
Old Jun 18, 2004 | 08:31 AM
fowls@blueyonder.co.uk's Avatar
fowls32
darren.cudd, can you tell me where you get the electronic fan controll and the alluminium hose adaptor from-is it easy to fit?
Old Jun 18, 2004 | 08:33 AM
CosRush's Avatar
CosRush
Im sure he can, while you're waiting....
Try
Demon Tweeks
Merlin Motorsport
Old Jun 18, 2004 | 09:25 AM
PGT's Avatar
PGT
cosrush - have not fitted ally rad yet cos i just took the motor apart (didn't need to really but kept me busy and out of the supermarkets and furniture stores for the winter lol - now 7.2cr cosworth pistons / ported head / greys/ t35 - t4 / cams / long studded block etc ) done 100 miles so far! when its done about 500 i'll put the other rad on but to B honest i dont think it will help a lot. my car was only running about 300bhp last year and on the really hot days the thing was cooking. still say that the air flow through the rush bonnet is the problem - in theory if you have a 2 litre mega turbo car idling it shouldnt run any hotter than a 2 litre non turbo but of course just after you have slowed down you might have shed loads of heat around to dissipate. anyway the rad still is much smaller than most 2 litre cars' (and you cant get the airflow throgh the engine bay|)
Old Jun 18, 2004 | 09:52 AM
CosRush's Avatar
CosRush
You're right in what you...
Ive got the 5 bonnet slots, plus the intercooler slot, and flared side arches....
Although, having checked yesterday someone has suggested it could be the thermostat...
I found,
The top hose hose HOT (possibly from conduction)
Top 2 inches of rad HOT
Rest of radiator COLD
Fan cuts in and blows COLD air off the rad
Bottom hose is COLD
Might try with out the stat and see if it makes a difference before i shellout STUPID money for the 4x4 Thermostat...
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Si B
Sep 12, 2015 06:49 AM
