esc cos problem
Old May 14, 2005 | 04:39 PM
THE RADMAN's Avatar
THE RADMAN
Default esc cos problem
took it out last week and pulled up at a junction,then the revs went haywire and the engine died,started up again fine and been out a couple more times with everything fine but now its playing up again,ive stripped the i/s/c/valve and cleaned it all out,checked and gapped plugs ,checked all multiplugs etc,the 2 main loom plugs look fine but it doesnt seem to idle properly,and when changing up a gear seems to hesitate/misfire sometimes at low revs/boost,i tried holding the revs at 3 thou while it was stood in the garage but it kept fluctuating between 2.5 to 3 any ideas anyone? looks like it could be a trip up to stus if i can trust it to go that far
Old May 14, 2005 | 06:54 PM
cos jon's Avatar
cos jon
Hello mate, mine did nearly exactly the same as yours, started to be intermittent but then happened nearly everytime i took it out.
When you use part throttle does it feel jurky ??
Mine turned out to be the TPS, new on fitted it was good as gold !!
Old May 14, 2005 | 10:17 PM
THE RADMAN's Avatar
THE RADMAN
yes it does,ill have to give it a try,what colours yours? prob seen it around if your in lincoln
Old May 15, 2005 | 11:29 AM
Dave Henshall's Avatar
Dave Henshall
its not the colour that is important..... as both the 2wd and 4wd ones can be either red or black.
the part number is the important bit: 2wd: PF01. 4wd: PF09.
hth.
Old May 16, 2005 | 06:23 AM
THE RADMAN's Avatar
THE RADMAN
cheers dave,but i was on about the colour of his car,lol
Old May 17, 2005 | 11:56 AM
cos jon's Avatar
cos jon
The car is black mate, I saw yours about a week ago in Bracebrige heath when i was coming home from work, well i saw the huge gold rims first !!
Nice lookin motor, must have spent a bit !!!
Old May 17, 2005 | 04:04 PM
THE RADMAN's Avatar
THE RADMAN
ill keep an eye out for you next time,if i get it going again,lol
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
`spotty
Sep 25, 2015 11:41 PM
Russ Payne
Sep 25, 2015 08:29 PM
