EDIS timing check - Question?
Old Jun 11, 2004 | 09:01 PM
disc's Avatar
disc
Default EDIS timing check - Question?
Is EDIS-4 ignition timing can be checked with normal timing light? Cause Haynes says that special equipment must be used. I have checked my ignition timing with normal timing light and here must be a problem with readings or ignition timing itself, cause many sources like Autodata and ect. say that ignition timing must be 10 degrees BTDC but mine is 20 degrees!!! When HEGO is unpluged then - 16 degrees BTDC!!! Is that a problem due to not special equipment or its a EDIS-ECC IV modules fault?
Help needed! Please!
Old Jun 12, 2004 | 08:25 AM
JesseT's Avatar
JesseT
The timing is fixed to 10 degress btdc with the SAW signal (edis pin 3) disconnected.
Old Jun 12, 2004 | 01:24 PM
disc's Avatar
disc
Ok, i know that and already tried with pin 3 disconnected - rezult 10 BTDC. But then why mine is 20!?!?!
car is Escort 1 400cc CFI
Old Jun 12, 2004 | 03:17 PM
JesseT's Avatar
JesseT
Because the chip tells it to be 20btdc with the engine speed, map and throttle position. Do you have reason to doubt that it's wrong? Sounds about right for idle.
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Sjieter
Aug 5, 2015 09:47 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
