Chip Advice on a S2 RST
Old May 13, 2005 | 03:43 PM
davidnormanuk's Avatar
davidnormanuk
Default Chip Advice on a S2 RST
Hi all,
I have a MK4 Cabbie which I've converted to an RS back in August.
My other half bought me a Chipped ECU for Christmas. I put it on and the car wouldn't run at all. I found out the chip causes the electronic timing to be well off. Instead of 12 degrees it was running about 4. When I put the strobe on it with everything connected the timing mark hardly seems to move reagrdless of what RPM the cars running at. I set the timing mark to 12 degrees by altering the dizzy and seems to be running ok.
My question is, should I need to alter the timing as much as this when swapping the ECU. I have heard that it shouldn't be like this but i'm not 100% sure.
Any help on this would be appreciated.
Dave
Old May 13, 2005 | 06:06 PM
GrimmeRS2K's Avatar
GrimmeRS2K
some rs turbo ecu's can have the timing changed internally by the tuner who is installing it to suit the need of the setup of the engine
Old May 13, 2005 | 07:42 PM
Stu @ M Developments's Avatar
PassionFords Creator
You have either:
1) A dead ecu pressure transducer.
2) Squashed the pipe when youve installed the heater box back in
Old May 13, 2005 | 09:07 PM
Rs1's Avatar
Rs1
As above,been there, done that,got the tee shirt Dont forget to pipe the ecu up,that wee vac hose tends to suck air just a tad.
Old May 14, 2005 | 10:12 PM
davidreader5's Avatar
davidreader5
HI,
ALL ABOVE, BUT IF YOU NEED ANOTHER ECU I HAVE A SUPER CHIPPED ONE.
Dave R.
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Sep 29, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
