cossie wont start
Old Jun 6, 2004 | 03:01 PM
islesport's Avatar
islesport
Default cossie wont start
Help is needed, i fitted a new chip ( 270 bhp Turbosystems ) i had a BBR stage 1 fitted originally but it felt sluggish and not 270 BHP so i took the brain out and the chip is standard looking with a written sticker on it saying BBR STAGE 1. I took the BBR chip out and fitted the Turbosystem chip but now the car just turns over and wont start is there something i have to reset or does anyone have any ideas.
Old Jun 6, 2004 | 03:10 PM
Toe Knee's Avatar
Toe Knee
Sounds dodgy if all u did was change the chip mate Have u tried putting the BBR chip back in?! If it works then the new one is dud or isnt made for the ECU u have!!
Old Jun 6, 2004 | 07:45 PM
nicksaph's Avatar
nicksaph
hello mate
have you got the chip in the right way?
Old Jun 6, 2004 | 09:33 PM
richm's Avatar
richm
1. Have you got the right chip for your ECU? ie Level1/6/8 chips are not interchangeable, so you must have a chip that is suitable for whatever ECU you have.
2, Is the chip plugged in the right way round? The little notch in the end of the chip should face towards the edge of the circuit board.
3, Is the chip plugged in correctly and securely, with no pins misplaced and hanging out?
4, Is the main ECU connector plugged in securely and locked in position with the retaining clip?
Old Jun 6, 2004 | 11:04 PM
DazC's Avatar
DazC
If you have put it in the wrong way round then the chip will be fooked...
Karl 3dr
102
Oct 14, 2016 08:17 PM
carlo
24
Oct 5, 2015 08:20 PM
Alun Gregory
Sep 6, 2015 09:40 AM
Red_bull
Aug 9, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
