zetec turbo
Old May 1, 2005 | 02:50 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Default zetec turbo
hi tommy again,if i make a custom fuel rail what injectors would you recomend on 2l for about 250-300 bhp also can i just get ecu chiped or would it be better using cossy 2wd or4wd.I am using a rs 2000 fuel pump will this b ok or should i change.thanks
Old May 2, 2005 | 10:43 AM
tonyturbo's Avatar
tonyturbo
personally i wouldnt risk using the rs2000 fuel pump. would upgrade to a cossie one just to be safe.
Old May 2, 2005 | 03:58 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
thanks tonyturbo for the fuel pump info,can you help with other bits,thanks
Old May 2, 2005 | 04:09 PM
tonyturbo's Avatar
tonyturbo
i'm assuming its a mk5 xr3i?
you could use your existing inlet manifold with either a frst fuel rail or i'v also heard you can use a 8v astra gte fuel rail. not so sure on injectors. i am personally running biege injectors whilst i run it in but these will need to be upgraded b4 i get it mapped. what to i dont know.
AVA in glasgow turbo charged a mk3 fiesta zetec and they ran the standard management on its own with a injector driver running 4 additional injectors. this kept wiring very easy.iirc it was producing 280bhp. hope this helps.
Old May 2, 2005 | 05:19 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
thanks mate you have been a big help,do you think ava would install inj drivers and map it if i done rest of work or dose it look a easy job to do,Q are you running zetec turbo
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
