Ive been told to use 10/60???????? Not sure what too do now lol
You can. But the only 10W60 oil I can recomend with clean heart is Castrol TWS Motorsport 10W60 which in UK is only obtainable through BMW dealerships. DO NOT USE CASTROL RS 10W60!!
Why Not use RS10w60. This is all i have used for three years with absolutely no problems at all.
Generally because it is not what you are paying for. Current formulation of Castrol RS 10W60 has nothing to do with original formulatin from early 90's. Leaves terrible waste buildup inside the engine too. Much worse oil then it used to be.
