Are the fuse boxes on Mk6/7 escorts all the same ?
HI all
I need a fusebox for my 97 escort. Seen a few on eBay but some say Mk5 Mk6 Mk7 ect. Was wondering are they all the same only difference is the location on where you put the relays and fuses to the spec of your vehicle.
Thank you
Thank you
No they are slightly different and there were different revisions. Although some can be adapted - its far less hassle to try and get the same code that you already have where possible. The lower the spec of your car, the more flexible you can be however.
Mk7 Escorts don't exist btw - Mark 1/2/3/4/5a/5b/6
allkarma (02-12-2022)
Hi if this is for your heavy water damaged escort i think your wasten your time really mate.. if you want to sort it out you really far better off trying to get everything as one eg fuse box ecu alarm ecu with keys etc otherwise your chasen and chasen issues
allkarma (03-12-2022)
